Using AC With LEDs (Part 4) - the New Technologies
Intro: Using AC With LEDs (Part 4) - the New Technologies
Some of the roadblocks in general acceptance of LED in the home has been the relative high cost per lumen and the complicated and clumsy power conversion systems.
In recent months, a number of new developments promises to bring us a step closer to a LED-powered world.
Taking its cue from the ATX system which powers our computers, a new line of "Green-mode" adapters will convert any voltage from 100v to 240v, AC or DC, to run combinations of 1- or 3-watt LEDs in numbers from 1 to 7. These modules are under 1" in length and can actually be inserted inside the base of a household light-bulb.
Here, I've chosen a conversion module designed to power a single 3-watt LED at about 700mA, but have attached it to 8 x 100-milliAmp "Superflux" LEDs in parallel, which allows me to simplify heat-sinking and light dispersion.
The entire assembly can fit on a board 1.5" on each side.
STEP 1:
The module can be obtained here for about US $3.00 in single quantities, shipping included.
The 3-watt design means that there is no voltage over 5-volts on any of the LEDs, and they are completely isolated from the mains.
The large "MHX" capacitor seen in the images is used to filter the input, so its wire leads do carry high voltage. Cover them with electrical tape to be safe.
The "Green-mode" design rectifies and smooths out the mains voltage and uses it to drive an oscillator at about 100KHz. This square-wave is applied to a small flyback transformer which converts it to a much lower voltage . The currents in and out and the temperature are measured 100000 times a second and the oscillator is turned off until proper operation is restored.
STEP 2: The LEDs
The LEDs I'm using here are 100mA (so called 0.5-watt) "Superflux" or "Piranha" LEDs. You can get them here.
They are able to handle this power without over-heating because cooling fins are built-in under every module.
The close-up shows sets of gold wires which go through the phosphor into 3 over-sized LED devices. Under low power, the separate diodes can be seen.
STEP 3: Construction
Construction is very simple - I used a small (2" x 2") piece of perf-board. Connect all the LED Anodes (+) together, then to the Red wire of the module. Do the same thing for the Cathodes (-) and attach to the other (white) wire.
The remaining white wires are attached to AC-mains.
STEP 4: The Light
I took this uncorrected composite with the white-balance set to "daylight". On the left is with a 50-watt halogen, and on the right, what it looks like with our 3-watt LED "bulb". The last picture is the same view with the LED light on the left.
Although seemingly very blue, the LED light's spectrum is almost identical to noon-day sunlight, and is what our eyes see best with. As an experiment, cover half of the picture with a piece of paper and see how fast your eyes adjust to the different light spectrum.
STEP 5: Another Lighting Test
And here, the first picture under a 15-W fluorescent.
The second with the 3-watter, using the same exposure.
STEP 6: Other Options
This commercial unit, also featuring 3-watts of power, costs US $20.00.
However, the beam pattern is definitely Spot, so room lighting is not its strong point.
Ours can be built in an hour or so, for about $10 in parts.
And it provides soft, even lighting for the entire area.
Again, exposures are identical, uncorrected and set for 'daylight'.
Note:
This is a continuation of my "Using AC with LEDs series", see my previous articles for background on this technology. Part 1, part 2 and part 3.
More information about constructing LED circuits can be found on my website here.
Note:
107 Comments
jenov 10 years ago
qs 10 years ago
To be safe, use the specified output voltage range and divide it by 3.3v (use 2.2v for IR, red, yellow and orange). Round it up to get the minimum number of LEDs to connect in SERIES. Then take the output current and divide it by the operating current through each LED. It is advisable to use 15mA for multiple LED setups like this, and to maximize the higher efficiencies of the LEDs at this current.
Note that with 120 LEDs, you can direct drive off mains. For 110v, just connect 2 rows of 60 in opposing polarities. For 220-240v, a simple bridge using four 1N4002 will drive an entire chain of 120.
ttvaisakh 8 years ago
please provide the designing details
thinders 10 years ago
Stupid Q # 362 ....I want to build some of these, but want to use them in existing 115 VAC lights, regular, not floods .....is there a screw type base that I could use for this project?
qs 10 years ago
It may be much easier by purchasing a LED bulb. Check this link on eBay:
http://www.ebay.com/itm/181269022420?_trksid=p2055119.m1438.l2649&var=480297621692&ssPageName=STRK%3AMEBIDX%3AIT
nolte919 15 years ago
qs 15 years ago
Seriously, the lumen/watt output of LEDs go down the harder you drive them - a complete reversal to what we've learned with incandescent bulbs.
So, not only would 8 LEDs allow me to run things a bit cooler, it actually produces a tiny bit more light than 7 LEDs would!
stp715a 12 years ago
Thanks
qs 12 years ago
arirang777 15 years ago
qs 15 years ago
qs 15 years ago
The advantage of splitting up 700mA into smaller 80mA lights is that the current loss is 100 times less (Ploss = i*i*R), so thinner wires may be possible. Probably #26AWG wire if the distance between lights is under 10-ft.
When you say "add up to 700mA, or MORE" does that mean greater than 9 superflux LEDs? Can 20 superflux LEDs be used on the single controller?
Thanks
qs 12 years ago
Do you think I could use your AC design connecting (4) of these in parallel?
http://www.bigclive.com/happy.htm
Thanks
googolplex 12 years ago
qs 15 years ago
