Introduction: Using Azure IoT Central API in React App
This is a simple tutorial how to using Azure IoT Central API in React App.
- Wiznet W5100S-EVB-Pico
- Microsoft Azure Central
Step 1: Setting ‘.env’ File
1. Set value
Setting Host API Setting Authorization.
REACT_APP_FUNCTION_CENTRAL_ENDPOINT = "Insert your API"; REACT_APP_FUNCTION_CENTRAL_TOKEN = "Insert your auth token";
2. Caution
REACT_APP must be included in the variable name.
Step 2: Make ApiConfig File
- ‘Axios’ is an HTTP asynchronous communication library that utilizes the Promise API for browsers and Node.js.
- You can use ‘Fetch’
import axios from "axios";
- Declare the API and auth token set in .env file.
const apiEndpoint = process.env.REACT_APP_FUNCTION_CENTRAL_ENDPOINT; const apiToken = process.env.REACT_APP_FUNCTION_CENTRAL_TOKEN;
- Write a function that retrieves a value using the API
const getMonitorData = async (param) => {
const config = {
method: "GET",
data: JSON.stringify(param),
headers: {
Authorization: apiToken,
url: `${apiEndpoint}/.../${param}?api-version=1.0`, // insert your API
try {
const { data } = await axios(config);
console.log("get monitor data");
return data;
} catch (error) {
console.log(error);
return false;
