Introduction: Using Batch Files to Make a Friendly On-Screen Ghost
Step 1: 1. Open Your Editor
1. Click "Start" .
2. Click on the icon for Notepad, or type "Notepad" into the search bar.
Step 2: 2. Type Some Code
This step may sound daunting, but I promise to make it easy.
Once you have opened Notepad, click in the text editing field and type:
@echo off
This line of code stops the program from enabling certain functions that could prevent it from working.
Now, copy and paste the following into your notepad:
PAUSE
cls
color 0a
echo.
echo.
echo.
echo.
echo.
echo.
echo.
echo ************************
echo ********* * I'm A Ghost! Boo! *
echo *********** ************************
echo ************* **********
echo * ***** * ******
echo * ***** * ****
echo * ******* *** **
echo * * ***** * * *
echo * * ***** * *
echo **** *** ****
echo *** ** ***
echo ** * **
echo * *
echo.
echo.
echo.
echo.
echo.
PAUSE
You can change what the ghost says if you want, I used "Hello!" as an example.
You can also change the ghost's color. This program makes a green ghost.
You can alter his color by changing the number and letter that follow the "color" line.
Step 3: 3. Saving Your Ghost
In order to run this program as a batch file, you need to save it in the batch format.
1. Click on the "File" Button.
2. Navigate to the file called C:\Users\Your Username Here
3. Save The File as "ghost.bat"
It is important that the file ends with ".bat"
It lets the computer know that you have written a batch file.
Now Open Command Prompt by
1. Clicking "Start"
2. Clicking or Searching "Command Prompt"
Step 4: 4. Running Your Ghost!
1. Right click on the command prompt icon.
2. Click on "Properties"
3. Check the Full Screen Option
4. Click Ok.
Now,
1. Type cls and hit Enter
2. Type ghost.bat and hit Enter
3. Press Any Key...
And there is your ghost! You Did it!
Thanks For Reading This Instructable!
