Using Clove to Cure Toothaches
Intro: Using Clove to Cure Toothaches
Clove oil is hands down the most effective home remedy for tooth pain of any kind.
This instructable will show you how to make a decoction from whole cloves but I would be remiss if I didn't also mention that clove oil can be purchased from most pharmacies and is, due to the steam distillation process, much more potent and effective at relieving severe dental pain.
[However if you are suffering from severe tooth pain you should consult a dentist. Clove oil should only be used for temporary relief as prolonged use can deaden the nerve.]
Cloves have been used to treat toothaches since medieval times and knowing this trick can save you from experiencing a world of pain and discomfort. The active ingredient in clove oil is eugenol and this treatment is ideal for someone about to undergo a root canal or suffering from dry socket.
If you use clove oil to get relief from a simple cavity please do no do so repeatedly as it is possible to do more harm than good in the long run - only use this remedy to make the wait for your dentist's appointment go by more easily.
STEP 1: Whole Cloves
You can simply place a whole clove into your mouth on or near the tooth that hurts, bite down & grind to release the oils, and wait. You'll know the oil has been released when you sense a bitter taste and a tingling sensation on your tongue and gums.
Whether chewing a whole clove or using the oil you will want to spit - don't.
Wait a couple of minutes before rinsing your mouth out with water.
The analgesic effect should last a couple of hours and the bitter taste should subside in under ten minutes.
If you don't have access to clove oil and want to make a close approximation at home, grind whole cloves with a mortar & pestle, coffee grinder or blender.
You can also make clove tea to effectively relieve the pain with less mess - Thanks to putty1cat for sharing!
STEP 2: Make a Satchel
Cut a small square of cheesecloth, place a small pile of ground cloves in the centre and tie up with a piece of string.
You can also make a satchel full of whole cloves and chew on it. The oil will soak through the cheesecloth to your teeth and you won't wind up with bits of clove in your mouth.
STEP 3: Oil & Boil
Place the satchel into the canning jar and cover with oil. Seal the jar tightly.
Place the jar into a double boiler for 30-50 minutes, then let cool.
STEP 4: Wait & Apply
Leave sealed for 1-2 weeks to increase potency.
Add a few drops of oil to a cotton ball and apply to sore tooth.
39 Comments
Laynie 10 years ago
legionmanchild 10 years ago
bruce.desertrat 10 years ago
This is also used by dentists all the time. This is what's on the little q-tip they swab your gum with to numb it before sticking the novocain needle in, and mine packed in some when he attached a temporary crown.
Still, if you have tooth pain at all, you should have it checked by a dentist, severe or not...getting some mild pain checked out can well prevent going from 'hey this tooth is sensitive to cold' to ' ouch ouch ouch ouch now I need a root canal!'
kennan 10 years ago
alannarosewhitney 10 years ago
Clove / clove oil has also traditionally been used to sooth sore muscles and other aches besides dental pain. Just use it as a topical salve and don't get it into an open wound, cut or scratch, etc.
kennan 10 years ago
Yashfa Zafar 10 years ago
whitepaper_01 10 years ago
My grandmother forced this "old-wives B.S." upon me.
I was just about to kick her so I could get away when the pained stopped.
After that I pestered her to teach me everything she knew.
She knew a goddam awful lot !!
It was more than once she tried to get rid of me with her boot. But I kept on at her.
I only recently learned that her whole family has this knowledge and that she never went to the hospital once in her life.
Are you kidding me or what!!
Now that ive taught my sons and daughter the same (although I cant recall how i did it) Im pretty sure now that that old woman tricked into learning and passing on that "old wives B.S"
krushio1 5 months ago
sirrush42 4 years ago
I'd suggest using pure coconut oil, as it tolerates high temps and has it's own antiseptic properties. Plus it helps quite a bit, to take the edge off the bitterness of the cloves. Also, if you adjust the clove to oil ratio, you can get a more potent oil right away rather than the 2 wk wait.
NancyJ73 5 years ago
I have a cranky tooth that will be coming out next appointment. It is a upper tooth cavity. I have the clove oil, can I do the cotton ball and clove oil. Tooth is loose but now cranky. My new dentist is for Oregano oil and most likely for clove oil. Liked your tips.
MaureenA18 6 years ago
ccc0706 9 years ago
TinaM170 6 years ago
AllisonS49 7 years ago
I live in Barbados and we do have clove oil hear a lot, but i guess your mother would have gotten a saucepan and cloves put it on the stoves with heat turn down untill the oil came frm the clothes or u can try amazon
patty.welch.77 9 years ago
JadeB34 6 years ago
mmarchesoni 10 years ago
when it occours, a really good shortcut is to apply the light from a red laser pointer over the sore tooth for a few seconds up to a minute, 3 times a day or more, if necessary.
Common red laser pointers, these ones of 5mW only, works very very well, and are quite safe if no one decides to aim it on others eye, just for fun.
Johno van Voornveld 8 years ago
mmarchesoni 8 years ago
Yes, it helps very well. I hope you never get a chance to try it yourself, but if it happens, try it
I've used it a few times myself, one time with a ex-girlfriend, with some friends and relatives until now, all with good results.
I've also commented with a two dentists who doesn't belive like you do, but they tried lasers and confirmed the efficacy.
