Introduction: Using ESP-01 and Arduino UNO
In our previous tutorial, we learned how to set up the ESP8266 ESP-01 and establish communication with other devices.
In this tutorial we are going to show how to use the ESP-01 module to give the Arduino UNO access to a Wi-Fi network and interact with inputs and outputs.
Step 1: Materials
The materials that you will need for this tutorial are:
Add the LED and button to the wiring setup from the previous tutorial as shown in the images above.
Note that TX and RX from the ESP-01 are now connected to pins 7 and 6 correspondingly.
Step 2: Coding
Now that we have the setup complete, we are going to control the LED via Wi-Fi to turn it ON or OFF.
We are also going to check to make sure that when the button is pressed that a message is received about its change of state.
The following code shows how to do this:
#include
//#include
#define TIMEOUT 5000 // mS
#define LED 5
SoftwareSerial mySerial(7, 6); // RX, TX
const int button = 11;
int button_state = 0;
void setup()
pinMode(LED,OUTPUT);
pinMode(button,INPUT);
Serial.begin(9600);
mySerial.begin(9600);
SendCommand("AT+RST", "Ready");
delay(5000);
SendCommand("AT+CWMODE=1","OK");
SendCommand("AT+CIFSR", "OK");
SendCommand("AT+CIPMUX=1","OK");
SendCommand("AT+CIPSERVER=1,80","OK");
void loop(){
button_state = digitalRead(button);
if(button_state == HIGH){
mySerial.println("AT+CIPSEND=0,23");
mySerial.println("Button was pressed!
delay(1000);
SendCommand("AT+CIPCLOSE=0","OK");
String IncomingString="";
boolean StringReady = false;
while (mySerial.available()){
IncomingString=mySerial.readString();
StringReady= true;
if (StringReady){
Serial.println("Received String: " + IncomingString);
if (IncomingString.indexOf("LED=ON") != -1) {
digitalWrite(LED,HIGH);
if (IncomingString.indexOf("LED=OFF") != -1) {
digitalWrite(LED,LOW);
boolean SendCommand(String cmd, String ack){
mySerial.println(cmd); // Send "AT+" command to module
if (!echoFind(ack)) // timed out waiting for ack string
return true; // ack blank or ack found
boolean echoFind(String keyword){
byte current_char = 0;
byte keyword_length = keyword.length();
long deadline = millis() + TIMEOUT;
while(millis() < deadline){
if (mySerial.available()){
char ch = mySerial.read();
Serial.write(ch);
if (ch == keyword[current_char])
if (++current_char == keyword_length){
Serial.println();
return true;
return false; // Timed out
Step 3: Code Explanation
#include <SoftwareSerial.h> #define TIMEOUT 5000 // mS #define LED 5 SoftwareSerial mySerial(7, 6); // RX, TX const int button = 11; int button_state = 0;
In this part of the code, we include the SoftwareSerial library to allow pins 6 and 7 to receive serial communication from the ESP-01.
We also assign the name “LED” to pin 5 and “button” to pin 11, and make the initial value of the button zero.
Step 4: Code Explanation - Continued
void setup()
Serial.begin(9600);
delay(5000);
}In the setup, we make the LED an output and the button an input.
We then begin serial communication and define the baud rate for both channels of communication.
Next, we call the function “SendCommand” several times to configure the ESP-01.
With this function you avoid having to open the serial monitor and sending commands manually like we did in the previous tutorial.
First we reset the module and wait for a couple of milliseconds to let it finish.
Then we make it operate in STA mode and ask for the IP address.
Finally, we enable multiple connections and start the server at port 80.
Step 5: Code Explanation - Continued
void loop(){
mySerial.println("<h1>Button was pressed!</h1>");
delay(1000);
StringReady= true;
if (StringReady){
}In the loop, we read the state of the button and assign it to the variable “button_state.”
Then we check if the button is pressed.
If the case is true, we type the command “AT+CIPSEND=0,23” to send 23 bit of data through channel 0 to our device connected to the ESP-01. Then we type the message that we want to send. In this case the message is “Button was pressed!” Note that we can use html formatting to edit the text and make it a header.
Next, we create a string variable that will hold the data coming from the ESP module. Once all data has been read we check if the received data contains either a string equal to “LED=ON” or “LED=OFF” along the lines.
If the first case is true, the LED is turned on. If the second case is true, the LED is turned off.
Step 6: Code Explanation - Continued
return true; // ack blank or ack foundThe “SendCommand” function takes two arguments: the AT command that we want to send to the ESP-01 and the acknowledge string.
The first argument is used to send a command to the ESP-01 through the serial channel.
The second argument is used to verify that the command was successfully accepted by the ESP module.
Step 7: Code Explanation - Continued
Serial.write(ch);
Serial.println();
return true;
}The last function is used to compare the acknowledge string to the response given by the ESP-01 once a command has been sent.
First we initialize the variable “current_char” to zero. This variable will serve as an index to compare each character between the acknowledge string and the ESP response. Then we store the length of the acknowledge string in the variable “keyword_length” and create a deadline that equals to the time since the Arduino board began running plus 5000ms.
Next we create a while loop that runs until the deadline is met. Inside the while loop we check if there is data to be read in the serial channel connected to the ESP. If the case is true, then we compare the acknowledge string to the data being read from the serial channel.
If both are equal, then the function returns a true to tell the program that the ESP-01 has responded accordingly to the command sent. If the deadline is met, then the function returns a false, meaning that something went wrong and the ESP was not able to respond to the command sent.
Step 8: Results
Once we upload the code, we can open the serial monitor. We will get the information shown in the image above.
This means that the configuration of the ESP was successful, and it is ready to be used as a server.
Step 9: Results - Continued
Now we can open a web browser and type either of the following lines shown above in the screen shot images of the browser windows.
The first line is used to turn the LED on, and the second line is used to turn the LED off. The images above show the lines written into the browser as well as the corresponding action that occurs on the breadboard.
Step 10: Results - Continued
If we press the button, we get the following message in our web browser’s window.
Step 11: Results - Continued
If we use the Android App “Mobile Telnet” we can get the same results.
First we need to open the App and connect to the ESP module as it was done in the previous tutorial.
Once we are connected we can type a message to turn the LED on, as shown in the image above.
Step 12: Results - Continued
Similarly, we can send the following message to turn the LED off.
Shown above in the screenshot image.
Step 13: Results - Continued
If we press the button we get the same message as before on our phone.
Now you can manipulate inputs and outputs via Wi-Fi using the Arduino UNO and the ESP-01 module in the ESP8266 series.
If you have any questions about this tutorial, do not hesitate to post a comment, shoot us an email, or post it in our forum.
Check out Jaycon Systems online store for the parts you need to start creating!
If you haven't already - read through the other great tutorials we have on our website as well as our Instructables profile!
Let us know what you think, and thanks for reading!
