Introduction: Using Ethernet Shield to Send ARDUINO Sensors Data to a MySQL Database and Display It on a Website With PHP, HTML & CSS
For this, you will need to have basic knowledge on Arduino Programming, MySQL, PHP, HTML & CSS (optional)...
Step 1: Things You Will Need
Arduino Development Board (Arduino Mega 2560 Recommended)
Arduino Ethernet Shield
A Wireless Router with Internet Connection
Cat 5 RJ 45 Connector Network Cable (any other can work) (check the images and pick one)
3 Male - Female Jumper Wires and some Male To Male Jumper Wires
A Web Hosting Account (get a fee one at 000webhost.com or 0fees.us, i used 000webhost.com)
DHT 11 / 22 Temperature Sensor
LCD 16X2 LCD Display
A Breadboard
MySQL Connector Library (Download from github Thanks to ChuckBell)
I got the hardware from amazon and I am sure they still have some more... :-)
Step 2: Connecting Things Together
The Ethernet Shield
Stack The Ethernet Shield over the Arduino Mega Board. (make sure all the pins are in their respective holes)
The DHT 22 Sensor
Connect the +pin (left most) to the +line(red Line) at the edge of the breadboard
Connect the -pin / Ground pin(right most) to the -line (Blue line) at the edge of the breadboard
Connect the out pin to digital pin 2 of the Arduino
The LCD
Connect as follows
Pin 1 (VSS) -> Pin 16(K) To the ground of the breadboard
Pin 2(VDD) -> Pin 15(A) To the +line of the breadboard
pin 3(VO) Through a 1kohm resistor to the ground
Pin 4 (ES) To the Arduino 32
Pin 5 (RW) To the Ground
Pin 6 (E) to the Arduino 30
Pin 11 (D4) to the Arduino 28
Pin 12 (D5) To the Arduino 26
Pin 13 (D6) To the Arduino 24
Pin 14 (D7) To the Arduino 22
The Breadboard
Connect the Red Line of the breadboard to the 5V of the Arduino
The Blue Line to the Ground
Step 3: Deploying
Download the zip file and extract it
copy the ev folder into the htdocs directory of your web server
goto the browser and type in localhost/ev/setup.php
the script will setup the sql database and tables
goto the codes folder and
open the ev.ino file in arduino and upload to the arduino mega board
set the baud rate to 115200
when it is done uploading and everything is connected properly
you
Step 4: The Working
If you like this project please vote me up and hit the like button...
