Introduction: Using Fusing (Glass)
This is a basic introduction to fusing glass. Fusing is a technique of joining pieces of glass together by melting them in a kiln.
Step 1: Tools
Kiln
Pyrometer
Glass prepared for firing
Fiber frax or kiln wash
Step 2: Load Kiln
In this step, great care should be taken to ensure that the glass is properly spaced and clean.
Step 3: Fire the Kiln
The kiln is fired to 1575 degrees at which point the two glass pieces should be fused.
*This requires a separate instructable of firing schedules of temperatures depending on the type of glass, the thickness, desired result, as well as the kink of kiln you are working with.
Step 4: Finished Artwork
After the kiln is unloaded, view your work.
3 Discussions
6 years ago on Introduction
amazing job is done here.....greate!!!
12 years ago on Introduction
gorgeous! I love fused glass. I really like the clear ones with leaves. I don't have the big bucks for the gigantic kiln. Someday I will make a parabolic solar kiln and maybe that could work.
Reply 12 years ago on Introduction
Thanks. I have found that fused glass is a very versatile material to work with. The clear glass pieces you commented on have copper wire (inclusions) in them. The wire is outlining the leaves. A solar kiln sounds very cool. Let me know if that works.
