Introduction: Using PSP As Computer Joystick and Then Controlling Your Computer With the PSP
You can do many cool things with PSP homebrew, and in this instructable I cam going to teach you how to use your PSP as a joystick for playing games, but there is also a program that allows you to use your joystick as your mouse.
Here are the materials needed for this instructable:
EDIT: I made this instructable in December of 2006. At the time, 2.8 was the highest firmware that could be downgraded. Check PSPupdates.com to see the latest version that is able to be downgraded.
A PSP that can have homebrew on it. ( 2.80 or lower firmware)
A wireless router or wireless access point that is already configured on your PSP via infrastructure mode.
The PSP Wifi controller homebrew application
PPJoy
Total Game Control
All of the above are direct links to the download. Here are the websites for those three programs.
PSP Wifi Controller
PPJoy
Total Game Control
PPJoy
Total Game Control
PSP Wifi Controller
PPJoy
Total Game Control
Step 1: Installing Wifi Controller on Your PSP
After you have downloaded Wifi Controller, now it is time to install and configure it. First, we need to find your IP address. For this, go to Start-> Run, and type in cmd. Then when command prompt comes up, type in ipconfig. Copy down the IP address. After this, open the Wificontroller zip folder. Extract it to somewhere where you know it is. Then copy the PSP folder (inside 1.0 or 1.5 folder) to the root of your PSP. If you have firmware 1.5, install the 1.5 PSP folder, and if you have 1.00 or 1.51+, install the 1.0 PSP folder. Then open the PSP folder, then Game, then wifi controller on your PSP. After this, click on wifi.cfg and edit it with notepad. Replace "192.168.0.10" with the IP address you copied earlier.
Step 2: PPJoy Intallation and Configuring
Install PPJoy. Then go to start- programs- Parallel Port Joystick- Configure Joysticks, or go to Control Panel- Parallel Port Joysticks (in classic view). After that, click on "PPJoy Virtual Joystick1" or if its not there make it yourself. Then click on PPJoy Virtual Joystick1 and click mapping, next, and the following options. (Just look at the pictures)
Axes = 2 (X Axis and Y Axis)
Buttons = 9
POV hats = 1
Next
X Axis = Analog 0
Y Axis = Analog 1
Next
Button 1 = nothing
Button 2 = Digital 0
Button 3 = Digital 1
Button 4 = Digital 2
Button 5 = Digital 3
Button 6 = Digital 4
Button 7 = Digital 5
Button 8 = Digital 11
Button 9 = Digital 10
Next
Directional button POV
North = Digital 6
East = Digital 7
West = Digital 9
South = Digital 8
Finish
Now on to testing.
Buttons = 9
POV hats = 1
Next
X Axis = Analog 0
Y Axis = Analog 1
Next
Button 1 = nothing
Next
North = Digital 6
East = Digital 7
West = Digital 9
South = Digital 8
Finish
Now on to testing.
Step 3: Starting on PSP and Testing.
Click the WifiController application inside the PC folder of the WifiController folder. Turn on your PSP. Go to game- memory stick- and then click on wifi controller. Select your connection. Then wifi controller should connect to your computer. If it does not, retry the previous steps or post it in your comment. After this, on control panel (classic view), and click on game controllers. Then click on PPJoy Virtual Joystick 1 and then Properties. After this, pressing buttons on your PSP will make the axes, buttons, or point of view hat move. Try out these and calibrate the PSP analog stick. Your PSP has successfully been connected to your computer. Now to make your PSP a computer mouse and keyboard.
Step 4: Installing and Configuring Total Game Control.
Install Total Game control and then start it. Where it says profile, click new and name it whatever you want (PSP is a good name) On device, click on PPJoy Virtual Joystick 1. Then click on the mouse tab. For left-right movement, click detect. On your PSP, move your analog stick left or right and it should say "Axis_X0". While still holding left or right on the analog stick, uncheck the detect box. Do the same for Up-down movement. Up-down movement should say "Axis_Y0". Then configure the rest of the controls to your preference and click "mouse controls always active".
Step 5: Have Fun.
This is my first instructable and I hope you liked it. If you have any questions please ask them. Thanks.
