Introduction: Using WiiChuck Adapter With Arduino
The Nunchuk is a very versatile tool. Contained in it are a 3-axis accelerometer, a two-axis joystick, and two pushbuttons for around $20. And you can even buy a wireless nunchuck to use as a controller! But many don't want to cut off their nunchuck connector. So here is an alternative.
In this Instructable I am going to show you how to connect the Nunchuk to the Arduino via the WiiChuck adapter. There are a couple of steps to this, first, we will hook it up, then we'll download the library and then download the code.
MATERIALS:
1 WiiChuck Adapter
4 Jumper Wires
1 Arduino Board (with USB Cable)
1 Nunchuck
MATERIALS:
1 WiiChuck Adapter
4 Jumper Wires
1 Nunchuck
Step 1: Plugging in the WiiChuck
First, open up the WiiChuck and solder 4 wires into the board. If you look closely you will see that the board is labeled, so follow these instructions:
GND to GND (obviuosly
+ to +5V
C to Analog Input pin 5
D to Analog Input pin 4
Then plug in the board with the labels facing the groove on the nunckuck, as shown in the picture.
I soldered the wires going away from the labels, so just make it so the wires are point in the same direction as the groove.
+ to +5V
Step 2: Getting the Library
Go here, scroll down to software, and dowload the zip file called Wiichuckdemo.zip. (Note: Look around this page, you'll find a lot of useful information on the WiiChuck.) Unzip the contents and go into the program files of your computer. From their, go the the Arduino IDE folder. Then, do this: libraries -> create a new folder called WiiChuck, and paste the contents of the folder into the new folder. Then open up the Arduino program and go to sketch -> import library -> Arduino. then open up the WiiChuck folder and open the WiiChuckdemo.pde file. Then download it to the board. Remember, the program uses 19200 baud, so when you open the serial monitor to check out the results, change the rate in the serial monitor to 19200. The play around with the buttons and the accelerometer. Here is an exaple picture:
Step 3: Play Around With It
Now, all you need to do is run the program and check it out! This has many applications, including my next project, a WiiChuck blackbox that logs accelerometer data. Please comment and rate, thanks!
