Introduction: Using an Anet Full Graphics Display on a MKS Gen 1.4, 1.3 & L Running Marlian 1.1.9.
I have seen many rewires and adaptors but also a lot of complaints and displays not working or damaged.
I wanted my E12 display to work with my new MKS Gen 1.4. So I was sure some software changes and two wires would only be the changes.
Follow these steps and yours will be working.
Update: I have checked the pinouts for the Gen 1.3 & L and updated this instructable.
Step 1: The Additional Code Needed Is the 1st Step.
This instructable assumes you know how to open and make changes to the Marlian 1.1.9. firmware.
- So open the Marlian.ino in the Arduino IDE.
- Find and open Configuration.h
- Find ANET_FULL_GRAPHICS_LCD
- If there are // in front of ANET_FULL_GRAPHICS_LCD remove the //. If you had to remove the // more than likely another display is defined, look through the LCD / Controller Selection and add // to the other display that starts with #define
- All others should look like these:
//#define REPRAP_DISCOUNT_SMART_CONTROLLER //#define ULTIMAKERCONTROLLER //#define ULTIPANEL //#define PANEL_ONE //#define G3D_PANEL //#define RIGIDBOT_PANEL //#define MAKEBOARD_MINI_2_LINE_DISPLAY_1602 //#define ZONESTAR_LCD //#define ULTRA_LCD //#define RA_CONTROL_PANEL //#define LCD_SAINSMART_I2C_1602 //#define LCD_SAINSMART_I2C_2004 //#define LCM1602 //#define LCD_I2C_PANELOLU2 //#define LCD_I2C_VIKI //#define SAV_3DLCD //#define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER //#define REPRAPWORLD_GRAPHICAL_LCD //#define VIKI2 //#define miniVIKI //#define MINIPANEL //#define MAKRPANEL //#define ELB_FULL_GRAPHIC_CONTROLLER //#define BQ_LCD_SMART_CONTROLLER //#define CARTESIO_UI //#define LCD_FOR_MELZI //#define U8GLIB_SSD1306 //#define SAV_3DGLCD //#define ULTI_CONTROLLER //#define OLED_PANEL_TINYBOY2 //#define MKS_MINI_12864 //#define CR10_STOCKDISPLAY //#define MKS_12864OLED //#define MKS_12864OLED_SSD1306 //#define MALYAN_LCD</p>
- FOR MKS Gen 1.3 & 1.4 boards
- Find and open the pins_MKS_GEN_13.h tab.
- Find where this code is:
// // LCD / Controller //
- Insert this code on the line after // and before #if ENABLED(VIKI2) || ENABLED(miniVIKI)
#if ENABLED(ANET_FULL_GRAPHICS_LCD) #undef BTN_EN1 #undef BTN_EN2 #undef BTN_ENC #undef BEEPER_PIN #undef LCD_PINS_D4 #undef LCD_PINS_ENABLE #undef LCD_PINS_RS #undef ST7920_DELAY_1 #undef ST7920_DELAY_2 #undef ST7920_DELAY_3 #define BTN_EN1 23 #define BTN_EN2 27 #define BTN_ENC 17 #define BEEPER_PIN 37 #define LCD_PINS_D4 35 #define LCD_PINS_ENABLE 25 #define LCD_PINS_RS 29 #define ST7920_DELAY_1 DELAY_NS(0) #define ST7920_DELAY_2 DELAY_NS(63) #define ST7920_DELAY_3 DELAY_NS(125) #define STD_ENCODER_PULSES_PER_STEP 4 #define STD_ENCODER_STEPS_PER_MENU_ITEM 1 #endif
- FOR MKS Gen L board
- Find and open the pins_MKS_GEN_L.h tab.
- Insert the following code on the line after #include "pins_RAMPS.h".
#if ENABLED(ANET_FULL_GRAPHICS_LCD)<br> #undef BTN_EN1 #undef BTN_EN2 #undef BTN_ENC #undef BEEPER_PIN #undef LCD_PINS_D4 #undef LCD_PINS_ENABLE #undef LCD_PINS_RS #undef ST7920_DELAY_1 #undef ST7920_DELAY_2 #undef ST7920_DELAY_3 #define BTN_EN1 23 #define BTN_EN2 27 #define BTN_ENC 17 #define BEEPER_PIN 37 #define LCD_PINS_D4 35 #define LCD_PINS_ENABLE 25 #define LCD_PINS_RS 29 #define ST7920_DELAY_1 DELAY_NS(0) #define ST7920_DELAY_2 DELAY_NS(63) #define ST7920_DELAY_3 DELAY_NS(125) #define STD_ENCODER_PULSES_PER_STEP 4 #define STD_ENCODER_STEPS_PER_MENU_ITEM 1 #endif
Compile and upload to the MKS board.
Step 2: Only Two Wire to Swap (+5v & GND) and NO Shaving Off the Key on the Connector.
After the program change, all of the output and input lines are lined up with the ribbon cable connector.
Now we need to swap pin 10 & 9 for the ribbon cable connected to LCD connector on the display. Note the connector we want to change has the key facing out (see photos).
We will be changing the wires that were pin 1 (red stripe) & 2 on the Anet board and now are pins 9 & 10 (red stripe) on the MKS. See photos along with the following steps.
- I did this by partly disassembling the connector.
- Clipping away the two wires together, peeling them back about an inch or two.
- Trimming off about 8mm from the end of these two wires, trust me do this.
- Turning them over where the red striped wire is inside of the ribbon. (see photo)
- Reassemble the connector.
- If you are unsure of your work then PLEASE check for a short across pins 1 & 2 before trying the cable.
- If everything is ok then plug it into EXT1
For the reset button, we need to connect pin 7 [extra ribbon cable on the LCD] to pin 8 on MKS EXT2.
See pinout images for your board if you are unsure of the reset pin location.
Turn on power to your MKS and watch the magic.
![How to Load New Firmware on [BTT] Bigtreetech TFT Displays](https://content.instructables.com/FCM/ENW4/K8LRQ8UD/FCMENW4K8LRQ8UD.png?auto=webp&crop=1%3A1&frame=1&width=130)
