Introduction: Using Gelatin for Moulds and Prosthetics
After my 'ible regarding using alginate as a mould making material, there were lots of questions about materials and obtaining them. Here's another method that uses only items that are readily available.
Gelatin is a much disregarded product when it comes to the home user.
It is safe to use and has some fantastic properties, it can be cast, or used to make moulds, it is re-usable (you just melt it back down) and best of all it's cheap and easy to get hold of.
It's safe (you can obviously eat it), but it's not just for cooking!
There are plenty of on-line tutorials on gelatin preparation for SFX, but they all call for some exotic ingredients. This 'ible uses only off the shelf stuff, but it works perfectly well.
You can store the prepared gelatin in the freezer for months, so make up a few batches and store them for future use.
In this Instructable we will prepare two types of gelatin mix, and look at their uses.
Step 1: The Basic Mix
We will need the following materials:
Gelatin, you want the crystal or powder type, not the sheets. This is available in the bakery section of your supermarket. Gelatin is an extract of beef so it's a natural product. It is used to 'set' various foods. Most notably Jelly (Jello), but it is found in lots of recipes. I use 'Dr Oetker', only because it's sold in Tescos.
Glycerine is a pure form of liquid syrup. Found at the drug store or pharmacy. Often used to sweeten kids medicines.
Liquid honey, or 'runny' honey. The stuff in a squeezy bottle will do fine.
Warm water, a plastic jug, some plastic cups, some stirring sticks (from the coffee shop), a small electric whisk. some washing up liquid, and access to a microwave oven
Step 2: Making the Basic 'goo'
The amounts are not too critical, but I generally use a small plastic cup as a measure.
1 part honey
1 part water
2 parts gelatin
2 parts glycerine
Fill one small cup with gelatin crystals and set to one side.
Take another small plastic cup and half fill it with warm water, add runny honey to top it off and give it a gentle stir to dissolve the honey. Pour the whole cup of honey into your plastic jug.
refill the plastic cup with glycerine and pour that into the jug as well.
Warm the jug in the microwave, on full power for 20 seconds and give the mixture a really good stir. You want the mix warm to hot but NOT BOILING.
Add the cup of gelatin to the jug and start stirring it, you want all the crystals to dissolve. Give the mix another 20 seconds in the microwave if the crystals won't dissolve. Keep stirring and heating as necessary to dissolve the gelatin and give a uniform colour and consistency. DON'T LET THE MIXTURE BOIL!
Step 3: Cool It All Down
Once the mix has become uniform and a sort of clear goldish brown colour, it's ready for cooling. Stick the jug in the fridge or the freezer and leave it for four hours.
The basic mix is now ready. It will take fairly rough treatment at this stage, so force a finger between the mix and the side of the jug and pull out the 'puck' of rubbery gelatin mix.
The pucks can be placed in a food bag and stored in the freezer until required. I make up a batch of 3 or 4 pucks at a time and store them.
Step 4: Using the Basic Mix
The basic mix has a number of properties. It is strong enough to take a fair bit of undercut, though not as strong as RTV rubber. It can be used to make moulds by simply warming it in the microwave until it becomes liquid, pour it over the pattern, allow it to cool and then remove the pattern.
It will cast almost any cold cure material such as resin or plaster, as long as the pattern can take the heat when pouring.
The basic mix also has a few other properties of interest. It has almost exactly the same mass and elasticity as natural muscle. Therefore it can be used to cast excellent prosthetics, you can use a plaster single mould, such as the ones used in my other 'ibles, or in a two part mould to create face masks and suchlike. These are described later in this 'ible.
Here is a link to the work of Peter Gaal (a true genius) using a latex bald cap and a gelatin 'nose' prosthetic to create an alien girl:
The work of Peter Gaal
Below is how to use it to make a simple mould. I have used the gelatin to cast a bolt to show the undercut it will take. The resin cast has retained the thread pattern.
Remember that resin heats up as it cures. Too big a piece and the heat will start to melt the gelatin.
Step 5: Foaming Gelatin
Now that we have the basic mix we can foam it to use instead of foamed latex. It is used in exactly the same manner as foamed latex, but does not require any sort of special baking or foaming agents.
Place a puck of the prepared gelatin into your plastic jug and gently re-heat it in the microwave until it becomes liquid. DON'T LET IT BOIL!
Give it a stir with a coffee stick to make sure it is nicely mixed. Then add two or three drops of washing up liquid to the jug.
Get your small electric whisk and starting on the lowest speed begin whisking the mixture. Once it has started to take air you can increase the speed. You want masses of tiny uniform bubbles. I whisked mine for around ten minutes until it had taken on about 3 times it's original size.
Put the jug in the freezer for four hours. Then pull out the large plug of foamed gelatin. It is very much softer and more pliable than the standard mix and will make really lightweight masks and prosthetics.
Step 6: To Make the Peter Gaal Nose
To make a two part mould prosthetic like the one in the Peter Gaal video, we need to make some moulds. If you want a mask to fit a specific person then you will need to cast their face (that's for another 'ible). Otherwise generic ones can be made using a glass head or similar.
I'm going to use my mannequin head as the face cast.
Using plasticine, plonk bits onto the face in roughly the areas that you want the final mask. Start smoothing out the bumps and joints with your fingers. The mask in the video is simple and effective to make, but you could make almost anything you want. Be careful in areas around the eyes and mouth because you will have to stick this on later and you don't want glue getting in your victims eyes.
Plasticine is oil based so for my final smoothing I use a bit of WD-40 on my fingers to blend out the edges. Once completed, we need to make a fence to hold back the plaster and give us a working area. I use more plasticine to build the fence up. Now I leave it for a while to have some tea and a smoke and let it all settle down a bit.
Step 7: Pour the Plaster
Once you are ready mix up some Plaster of Paris or casting plaster (I use Crystacal-R). Dental casting plaster is also good. If your head is made of plaster, then you need to add a mould release agent before starting on the negative mould. Use Vaseline or one of the silicone release sprays.
Plaster for casting is available at most art shops, or craft shops, or off the net. I ignore the fancy mixing formulae, two parts powder to one part water (by volume) will generally give good results every time. One cup of water to two of plaster. Start by getting a quick even layer of plaster all over the mask. If you use a brush be careful not to disturb the surface of the plasticine. I like the messy aspect of it all and get stuck in with my hands and fingers.
Once you have a base of plaster down, start slowly adding to the initial coat. If it all gets a bit out of hand, leave it for 20 minutes to set and then mix up some more plaster and add to the dried stuff. Slowly, slowly catchey monkey. You can add plaster bandage or scrim net to strengthen and support the plaster as you go. Eventually you want a mould at least 3/4" or 20mm thick.
Let the plaster dry for an hour. Another cup of tea and another smoke helps here.
After an hour you can de-mould. Start by pulling away the fence. this will leave a ledge around the upper plaster mould. Grip the edge with your fingers and gently ease the upper cast off the head. It doesn't matter if some of the plasticine comes away with the cast or stays stuck to the head.
Carefully clean away and remove ALL TRACES of the plasticine from both the head and the mould. When fitted back together this will leave a void into which will go our gelatin. Congratulations, you have just made a two part mould.
Step 8: Casting the Gelatin
We now have a head (the positive mould), and a mask cast (the negative mould).
The method here is to heat up our prepared gelatin in the microwave until it is liquid (don't let it boil). You can use the raw or the foamed mixes. I would recommend that for this small mask you use the raw stuff, for larger masks and prosthetics try the foamed. Once the gelatin is melted in your jug (remember not to boil it), you are ready to pour.
Turn the negative mould on it's back so that the void is uppermost. Pour in the gelatin mix until the void is full, this will be more than the void needs so remember to do this where any spilled gelatin can be easily cleaned off and reused. I use a board covered in melamine (an old white kitchen cupboard door).
With the negative mould on its back, place the positive mould into the void and press the two together FIRMLY. Be careful since hot gelatin mix is liable to be squeezed out of the mould, you don't want the hot stuff all over your hands!
Force the two parts of the mould together gently but firmly until the positive and negative moulds fit snugly back together. I wrap some insulating tape around them at this stage to hold them in place.
You can either leave this arrangement overnight at room temperature to cure, or place it in the fridge if it will fit. Four hours in the fridge or overnight should ensure that the gelatin has set. Open the moulds gently and peel out your mask. If you are careful the moulds should make more than one mask.
The mask can be used immediately or chucked in the freezer for storage. Once you are bored with the mask, give a rinse to get any make up or paint off and then just melt it back down in the microwave and make summat else with it.
Step 9: Colouring
Gelatin prosthetics will take normal make up, face paint or body paint well. Here I have added some normal liquid foundation and some powder to one side of the nose piece.
If your prosthetics have well feathered edges then you should be able to get a seamless blend. Use a little witchazel to dissolve away the edges.
Gelatin requires either Spirit Gum or Pros-Aide as an attachment glue.
4 People Made This Project!
- MaryO72 made it!
- DanaN3 made it!
- DJ_DarkOpz made it!
- Pris Nexus 6 made it!
157 Comments
4 months ago
Is there anything non - ant attracting to replace the honey? Long shot since this is 7 years old, but what is chemically happening w/ the honey? The honey seems to be softening the mold, right? Why? Are sugar (or sugar-like) compounds necessary (i saw someone mention sorbitol) for this levele of softness?
Question 9 months ago on Step 9
When you say parts for the basic mix, what amount do you mean? I see the recipe:
1 part honey
1 part water
2 parts gelatin
2 parts glycerine
I'm making my own prosthetics with plastalina clay. I want to make alligator scales. Please help
Answer 4 months ago
It depends what your final volume will be. Example - if you want to make 1 pint/473mL of this stuff, imagine 1/6* 473mL (or 1/6 times 1 pint) = ~79mL honey, 79mL water, (2 * 79) = 158mL gelatin, and 158 mL glycerine.
TLDR: So [your amount here total] divided by 6 (or multiplied by 1/6, same thing) = 1 part of material. Multiply that by 2 for the gelatin / glycerine since it is 2 parts.
1 year ago on Step 5
This is so awesome. Thanks for this Info. But what is washing liquid? Just like dish soap? Thanks
Question 3 years ago
Why wouldn't you bloom the gelatin first? Gelatin is a protein chain that absorbs water at lower temperatures. That's why all food handling of Gelatin involves rehydrating in cold water before heating - two step process. Heating without hydrating lowers the protein development and I would guess it's cutting down on volume, and adding to grain.
3 years ago on Step 9
Are you currently selling this prosthetic?
Question 4 years ago
What purpose does the honey serve?
Does one have to refrigerate the prosthetic when not in use?
Answer 4 years ago
The honey (or other sugar syrup) gives the gelatin it's elasticity and strength. Otherwise you basically get jelly / jello. The final product is a natural foodstuff, and when first mixed is essentially very hot toffee. Refrigerating will both cool it more quickly and keep it fresh. If left out for any great length of time it is liable to go mouldy. I also advise freezing it for longer storage for the same reasons.
i am trying to do a comic book character called the question here is a link so reference material
https://vignette.wikia.nocookie.net/marvel_dc/imag...
what thickness would you recommend for the mask? i seen videos on how to breath and see in said mask but they dont tell you how thick of thin you need to make the mask. i have my pucks made and ready along with my life cast. thanks for reading and have a nice day. if i need to give more details or other pictures of reference ill be more than happy to give more details
Answer 4 years ago
The gelatin is remarkably tough, but in reality I wouldn't go below 2mm / 1/16" at the thinnest section and would probably want at least 6mm / 1/4" except at the feathered edges.
Question 4 years ago on Step 2
Newbie here! You decribe the measurements as 1 part honey, 1 part water, etc. How much is a 'part'? My gelatine is in 5.2g packets. This is a dry measurement so I have no idea what the liquid measurements would be.
Answer 4 years ago
A 'part' is whatever unit of measurement you like. If you use 1g of one, then you use 1g of the other. If you use 1 ton of one then you use 1 ton of the other, if you use 1 fluid ounce of one then you use 1 fluid ounce of the other. If you use 5.2g of gelatine then weigh 5.2g of water and 5.2g of honey.
4 years ago
OK, Wow! Lots of questions and comments posted on this one! Sorry but due to various health issues and whatnot I haven't gotten around to many replies. However I will endeavour to try and answer those I can here. Firstly, please note I DO NOT LIVE IN AMERICA I have no access to half the brand names or products you have over there so I have no idea if they are the same or different from what I can get in Europe. I have deliberately used generic terms for the methods and ingredients used.
Firstly, what we are trying to make is a product that weighs and behaves in exactly the same way that your own muscles do. We're not making Jello or anything like it. You can buy professional SFX gelatin mix from a number of outlets. It's the stuff they really use in the movies and it comes as a rubbery block that you melt down and cast. Here is the exact recipe that they use:
1 part gelatin powder (300 bloom)
1 part glycerine
1 part sorbitol
The gelatin is the setting agent, the more gelatin the stronger the final product, but it is brittle (you can snap the sheets) and it's not elastic and it won't flex. It also needs a liquid part to make it dissolve. 300 bloom is difficult to obtain and far more expensive than standard food grade crystals.
The glycerine (glycerol) is used to prevent the gelatin from setting rock hard, which would not be much good for flexible prosthetic pieces, or for moulds.
The sorbitol is a sugar alcohol which has two functions. It acts as a dissolving agent for the gelatin and it interacts with the gelatin and glycerine to produce log chain polymer proteins which give the elasticity and flexibility. Sorbitol is also difficult to obtain and expensive. Along with the glycerine it helps to 'thicken' the mix a bit.
In my recipe I have substituted the solbitol with the honey / water mix. The water acts as the dissolving agent and the honey interacts with the gelatin and glycerine to produce the elasticity and the flexibility. Without this part I have no idea what sort of results you are going to get.
Adding things to the mix (like colourings and whatnot) may work, but they will change the properties of the mix and they are not recommended. You can probably substitute the honey for any other thickish sugar syrup, but we don't use corn syrup in Europe so I have no idea if it will work, Golden syrup will work, but maple syrup is too thin if that helps at all?
You do not have to 'set' the mix before you can use it, you can pour it as soon as it's all mixed and dissolved. I just tend to do a few batches and freeze them. So you don't have to put it in the fridge before you use it.
You don't have to use a microwave, you can do it in a pot on the stove or use a bau marie. Just remember not to let it boil because this breaks down the protein chains and makes the mix much weaker and less stable. It's also much easier to get the mix out of a plastic jug than a metal pan.
The melting point of professional SFX gelatin is around 70 degrees, my mix is about the same. It shouldn't melt under body temperatures, but I would avoid using it at midday in a desert. Under most 'normal' conditions it will behave just fine. It will not dissolve in water unless the water is very hot in which case your model will burn as quickly as the gelatin will melt. It will not dissolve in sweat either, but the glue might start to lift. This is a problem with all prosthetics regardless of what they are made of. Using Pros-Aide will stick like shit to a blanket, so I recommend using that.
As stated in the ible, if you try to use it against something that is very hot it will melt so don't do it. Since the mix is comparatively cheap feel free to experiment, the worst that will happen is that you'll end up with a big mess and have to start over.
Finally a word about moulds. There is an unwritten rule that you cast soft materials against hard materials and vice versa. If you try to cast or mould a hard product (like plaster) against a hard product (like plaster) and there are any undercuts you will either never get them apart, or you will shatter them in the process. Similarly if you try to cast or mould a soft material against a soft material, the mould will deform and the cast will not be the same as the original, or worse the two pieces will bond to each other and you will never separate them.
Remove any undercuts buy filling them and use a mould release agent. This gelatin mix is robust and can be pulled out of quite deep undercuts, but a solid mould might break under the strain.
Hope that helps everyone :-)
Si
Reply 4 years ago
would I still need to foam 300 bloom gelatin?
Reply 4 years ago
You only need to foam the mix if you want a very lightweight end material. In which case you would need to foam whatever mix you use.
5 years ago
I want to give this a try and it will be my first time making a prosthetic of any kind. I have been told that gelatin prosthetics don't hold up well because once they are applied they are easily melted by body heat and so cannot be worn for very long. Does this recipe resolve that issue? I want to be able to wear my prosthetic for hours without any melting issues.
6 years ago
Hi I was wondering if I could use this to make molds for hot sugar candies. I'm worried about it melting when I pour the hot sugar in. Any info would be great!
Reply 5 years ago
This stuff is basically jello. I'm not 100% sure on the numbers but I'm pretty sure molten sugar has a MUCH higher temp than the melting point of gelatine.
Unrelated note, molten sugar is scary flameable... You never quite forget lighting a spoon on fire in chemistry class. :P
5 years ago
can you do this without a microwave
5 years ago
can I use corn syrup rather than golden syrup? :)
