Introduction: Utility Sink Rack Made Using Upcycled Bicycle Spokes
Utility Sink Rack {Wall mount} for convenient storage, and drainage, of dish-washing utensils, washcloths and hand towels.
Supplies:
1.a. 3DPrint file: Sink-Rack V3.stl (listed below)
1.b. 3D Printer filament. Your choice of color and material type.
2. Reclaimed bicycle spokes: Acquire some Used Spokes [YouTube Video]: Reclaiming Bicycle Spokes
Tools:
You'll need a 3D Printer. Almost any commercially available printer will do {minimum bed size 200mm}; this project, along with my other '3-Bar' projects, is designed to produce acceptable results on even the least expensive and simplest 3D printers available. Your choice. I use an "old" Anet-A8 "kit" printer I bought for 150$ just to make sure the designs work on 'anything' :).
Tools List for using reclaimed bicycle spokes with 3DPrinting
- Small bolt cutters, similar to: [Small Bolt Cutters @ Amazon.com]
- Deburring Tool, similar to: [Deburring Tool @ Amazon], {not typically necessary, but nice to have handy.}
- Needle-noes pliers, similar to: [Needle-noes Pliers @ Amazon.com]
- Exact-o knife and blade(s), similar to: [Exacto & Blades @ Amazon]
- Small hammer, similar to: [Mini Hammer Multi-Tool @ Amazon]
- Sanding Block and Sand Paper, similar to: [Sanding Block @ Amazon]
- Calipers {not strictly necessary, but highly recommended} [Calipers 8" @ Amazon]
Aux. 'Clean-Up' tools list: {additional tools I like to keep handy}
- Rotary tool similar to: https://amzn.to/3pTrBoo
- Sand paper similar to: https://amzn.to/3IPjjGW
- Wire brushes similar to: https://amzn.to/30trbMU
- Dykes similar to: https://amzn.to/3m8aWwk
- Nail files similar to: https://amzn.to/3s8T5Jr
- File set similar to: https://amzn.to/3DYLr6M
Spoke Acquisition
- Spoke Removal Tool, similar to: [Spoke Tool @ Amazon]
- Screwdriver(s) { at least two } [ flat blade ] for wheel/tire disassembly
- OrTire Leavers [Tire Leavers @ Amazon]
The Flat Blade screw-driver(s) are necessary when removing the “used” spokes from bicycle wheels/rims. Optionally I’ve found ‘your local bicycle shop’ is a good place for finding used spokes, though they may charge for the items.
Step 1: Print the File
Slice the stl file using your favorite slicing software; which ever your printer requires. Then use your 3D Printer to print the associated file.
Step 2: Trim & Bend Bike Spokes
a. Trim the spokes to length:
#1. Trim: 60mm {Bend 15° at 30mm from tip; it helps to hold the sponge in place as shown.}
#2. Trim: 87mm
#3. Trim: 87mm
#4. Trim: 70mm
#5. Trim: 57mm
#6. Trim: 42+125mm (167mm) {Bend 90° at ~42mm from tip}
#7. Trim: 42+125mm (167mm) {Bend 90° at ~42mm from tip}
Note: Another ‘bend option’ exist; e-me 4 it. I also intend to ‘eventually’ include a video showing how to bend spokes more precisely; but simply put, you use the pliers and your hand/fingers to bend the spokes to 'about' the desire angle. It's not as if it's rocket science :)
Step 3:
b.1 Insert spokes into associated post-holes in the drainage sphere; use Superglue-Gel to cement firmly in place.
Note: Do Not use adhesive on #6 or #7 as these two can easily rotate; making them a bit more useful.
b.2. Allow 24hr cure time (Not strictly necessary ☺)
Step 4: Mounting
4. Mounting:
Method A. I use Nano-Tape as it does not damage the wall: https://amzn.to/3ENcMu5
Method B. Holes provided for “standard” mounting technique using #8 or #10 screws.
Step 5: Additional Info & Notes
Utensils (Suggestions Only, Shown in image)
Scotch Brite Heavy Duty Scouring Sponge: https://amzn.to/3yfvbND
Palm Brush: https://amzn.to/3DHxs57
Bottle brush: https://amzn.to/3DQziRk
Notes:
Like most Bicycle Spoke Re-Use/Up-cycle/Reclaim designs in the 3Bar series the Sink-Rack can be configured in more than one fashion. Specifically the two ‘top-spoke’ inserted spokes [#6 & #7 on the image above] can be bent to hold either hand towels {a bit longer} or wash cloths.
Simple to assemble: Printing takes a while but depends on print speed, as it always does, my print runs ‘about’ 9hrs at 70mm/sec, my preferred speed. Print options, including materials, are, of course, up to you. My machine is both old and cheap, and works wonderfully well even after all this time and abuse; it has more than payed for itself, plus it’s fun! :) a 3D Printer of your vary own is a Highly recommended tool/item for your workshop or garage.
