Introduction: Utilizing Information Regarding Parquet Flooring Refinishing Immediately
You stand to gain a lot of benefit when you have an effective parquet flooring refinishing. For starters, you will be able to restore the glamor. The intricacy that comes with the beautifully arranged wood planks makes this type of floor a winner. When you want to redo the floor, the top layer of the gloss should be removed. This is to protect the wood from staining.
This is a good way to restore your shiny floor. If you do not know how to go about it on your own, then you need to consult a professional. If you have the urge to do it yourself, make sure you understand how to go about it. Make sure that you retain the intricacy of the floor. The way you sand is key to achieving success on the finishing.
It could be a bit complicated when redoing the floor. This is because sanding or staining will not work well because of the grain of wood going in all directions. You should keep your focus to replacing the top gloss coating. Deep sanding or staining should be avoided. If you have to deep sand the floor, you ought to use a machine that is able to sand in all directions at once.
Make sure you are prepared for the job. Free the floor from obstructions. Before you decide to redo it, ensure that it has been cleaned well. You should remove all furniture from the room prior to beginning the task. In addition to that, remove the trim. Using a flat bar and a hammer should do this for you. Make sure you avoid cracking the trim.
Make sure you go over the whole floor to make sure that there are no nails that are raised. This is because they may cause many obstructions. The floor should be cleaned well using lukewarm water. You may choose to use a little dish washing liquid. Be sure not to leave any standing water as it could destroy the floor.
Begin sanding and remove the top layer of the gloss. Make sure to avoid sanding all the way into the grain. If you do not have an orbital sander, you could rent one. The reason you should use one is to have finer results. Begin by using a coarser sand paper then finish off by a finer one. This ensures that your floor remains smooth. After you are done, remove the dust with the vacuum cleaner. You will know you are done when the floor is dull and no visible gloss.
When finishing, begin from the farthest room corner. Use a Lambs wool applicator to apply the polyurethane gloss. You can strip off the gloss along the wall and pull the applicator backwards. Make sure the coat is thin and even. Be careful to avoid any bubbles forming. After you have done this, let it dry for at least a day.
After it has dried, use an extremely fine sand paper to hand-buff it. This ensures that your second coating will stick. Remove the dust formed before commencing on the second coat. After you are done, recap the same way before the third and last coat. Never sand the final coat. After it is dry, replace the trim back. When it is dry, you will notice that you were successful in your parquet flooring refinishing.
