Introduction: V Lift, a Knex Ball Machine Lift
Hello!
This is the sixth new lift first used in my ball machine Elysium.
It's a big lift that works slow as well, but it works fine and is cool to watch.
It can also be modified in many ways, so feel free to give it a try!
The side of the entrances can be adjusted, as well as the side of the exit. It's also possible to build a second exit, it's up to you what your V Lift will look like.
When you encounter a problem or have a question, you can always send me a message.
Thanks for watching / building!
~Sandroknexmaster~
Step 1: Piece Count
If you want you can count the pieces before you start building.
Here is a list with all pieces included in this lift, named by their original colour:
RODS:
Green: 80
White: 87
Blue: 201
Yellow: 218
Red: 214
Grey: 84
Total rods: 884
CONNECTORS:
Dark-grey: 27
Light-grey: 52
Orange: 21
Red: 91
Green: 28
Yellow: 139
White: 31
Purple: 218
Blue: 62
Total connectors: 669
OTHER:
Blue spacer: 147
Silver spacer: 205
Tan clip: 37
Y-clip: 30
Blue hinge: 2
Black hinge: 2
Small blue gear: 4
Medium red gear: 22
Big yellow gear: 4
Medium hub: 4
Medium tire: 4
Chain link: 219
Motor: 1
Total other: 681
Grand Total: 2234
Step 2: Frame
We'll start by building a frame that will hold the arms of the lift.
Step 3: Gears and Motor
In this step we'll build the gears and add the motor. We'll need two gearboxes, one for each side of the lift. Some parts are identical but there are also some differences, so pay close attention to pictures.
Step 4: Chains
Now we're going to add the chain. Make sure everything is attached correctly, double check to be sure everything is in the right position. If the grey rod attached to the chains is up on one side of the lift, then the grey rod on the other side has to be down. The grey rods also have to be horizontal. The four shorter chains have 41 chain links each, the longer chain that connects the two gearboxes has 55.
Step 5: Entrances
Here we're going to build the two entrances.
Step 6: Exit
In this step we'll make the exit.
Step 7: Arms
This are the two arms that give the lift its V shape.
Step 8: Arm Exits
The last step. First we're going to add the arm exits, and then we will attach the V shape to the frame.
Step 9: Finished!
The V Lift is finished!
Always slide the switch of the motor to the left.
~Sandroknexmaster~
