Introduction: V2 Acrylic Blue Mecanum Wheel Robot Car Kit for Arduino Mega2560
About: Osoyoo brand products are mainly focused on STEM education.User experience and customer feeling are always our first priority. Our goal is to create the best designed product to help students and hobbyist to e…
Have you ever dreamed of creating a robot that can move independently in all directions? The OSOYOO Blue Mecanum Wheel Robot Car Kit will turn your robotic dreams into reality. This article will show you how to use this kit to make your robot dance freely and explore a world of boundless creativity.
1. Introducing the OSOYOO Blue Mecanum Wheel Robot Car Kit:
The OSOYOO Blue Mecanum Wheel Robot Car Kit is an innovative robotics kit that features the Mecanum wheel design, giving your robot omnidirectional movement capabilities. Designed for robot enthusiasts, students, engineers, and makers alike, this kit provides all the essential components you need to easily construct, program, and control your own agile robot.
2. Build Your Agile Robot:
With detailed assembly instructions included, this kit makes assembling your robot a breeze. No advanced tools or skills are required – just follow the steps, and your robot will come to life in no time.
3. Creative Programming and Control:
The OSOYOO Blue Mecanum Wheel Robot Car Kit supports various programming platforms, such as Arduino. You can write code to control the robot to move forward, backward, sideways, or even rotate in place. This allows you to design unique actions and behaviors for your robot, turning your creativity into reality.
4. Endless Application Scenarios:
This robot kit is versatile and applicable in a variety of scenarios. Whether indoors, outdoors, educational environments, or entertainment events, it showcases remarkable agility and flexibility. From logistics management to educational displays, your robot will captivate audiences' attention.
5. Engage with the Community, Share Your Achievements:
On the Instructables.com community, you can share your journey of building the robot and your experiences. You can also gain inspiration and advice from fellow creators. Engage in conversations with creators worldwide, and have your creativity recognized.
You can buy it from Amazon or OSOYOO website.
OSOYOO blue acrylic mecanum wheel robot car kit (United State)
OSOYOO blue acrylic mecanum wheel robot car kit (United Kingdom)
OSOYOO blue acrylic mecanum wheel robot car kit (Germany)
OSOYOO blue acrylic mecanum wheel robot car kit (Italy)
OSOYOO blue acrylic mecanum wheel robot car kit (France)
OSOYOO blue acrylic mecanum wheel robot car kit (Spain)
Package List:
Acrylic black chassis x1
Gear motors x4
Metal motor holders x4
Mecanum wheels x4
Mega2560 board for arduino and cable x1
Uart wifi shield x1
Model Y 2.0 board x1
Voltage meter x1
Bluetooth module x1
Tracking sensor module x1
IR obstacle avoidance sensor x2
Mount holder for ultrasonic sensor x1
Ultrasonic sensor x1
SG90 Servo motor x1
LED lights x2
18650 battery box x1
Electrician tape x1
18650 batteries x2
Battery charger x1
3Pin female to female jumper wire x1
6Pin male to female jumper wire x2
10Pin jumper wire male to female 20cm x2
7Pin female to female jumper wire x1
2Pin 20cm XH2.54 female jumper wire x1
Screws package x1
Manual x1
Step 1: Basic Robot Car Assembly
Download PDF Tutorials:https://osoyoo.com/manual/2021006600.pdf
OSOYOO Robot car installation video: https://osoyoo.com/manual/2021006600.html
(1)Fix 4 motors with Metal Motor Holders as follows. (Please check the motor direction before installing metal motor holders.)
(2) Fix 4 motors on lower car chassis with M3*10 hex screws via hex screwdriver. (screws for this step are in metal motor holder package.)
(3)Install OSOYOO model Y driver board to lower car chassis with 4pcs M3 plastic screws,plastic pillars and plastic nuts.And connect 4 motors to Model Y 2.0 motor board K1 and K3 sockets as per following graph.
(Please make sure you install the OSOYOO MODEL Y 2.0 driver board in correct direction.)
(4) Install tracking sensor modules on lower car chassis with 2 pcs M3 plastic screws, M3 plastic pillars and M3 plastic nuts.
(5) Fix copper pillars with 6pcs M3*10 screws and 6pcs washers on lower chassis.
(6)Fix this Battery Box on upper chassis with 4pcs M3 x 10 screws and M3 nuts.
(7)Install voltage meter on low car chassis with 2pcs M3 plastic screws, plastic pillars and plastic nuts.
(8) Fix OSOYOO Mega2560 board on upper car chassis with 6pcs M3 plastic screws, 6pcs plastic pillars and 2pcs plastic nuts. (Please install Mega2560 board at the side with printing.)
Insert OSOYOO Uart WiFi shield onto your Mega2560 board.
(9)Install servo motor at the front of upper car chassis with 2pcs M2.2*8 Self Tapping Screws.
(10)Install 2pcs IR distance sensors with 2pcs M3 plastic screws, M3 plastic pillars and M3 plastic nuts at the front of upper car chassis. You can install M3 plastic screws under upper chassis in order to tighten IR distance sensors enough.
(11)Install 2pcs LED light on the front barrier plate as follows.
(12) Before combine upper and lower chassis into one, it need the circuit connection.
(13)Connect OSOYOO model Y board to OSOYOO Uart WiFi shield with 2pcs 6pin male to female jumper wires as follows. The 6-pin wires in Area B need to go through the hole near SG90 servo, the other 6-pin wires in Area A need to go through the hole near voltage meter.
Caution:
When insert/remove this 6-pin plug into Model Y 6-pin male socket, please hold the plastic pin-holder to do operation. Never drag the wires to pull the plug out of the socket, otherwise it will damage the wires.
If you receive the updated model Y driver board V2.0, please install it as follows.
(14)Connect voltage meter to OSOYOO model Y board with 3pin female to female jumper wire as below connection diagram.
Connect OSOYOO model Y board 12V-GND socket to VIN-GND socket with OSOYOO 2pin PnP cable 20cm as per following graph.
Connect battery box to VIN-GND socket of OSOYOO Uart WiFi shield according below connection diagram.
(15)Install 2pcs LED Lights on the front transverse diaphragm as follows.
Connect the LED light to OSOYOO Uart WiFi shield as follows.
(16) Connect SG90 servo motor, OSOYOO model Y board and OSOYOO Uart WiFi shield as following diagram.
(17)Connect GND-VCC pin of tracking sensor module to GND-5V of OSOYOO Uart WiFi shield V1.3; connect IR1, IR2, IR3, IR4, IR5 pins to A4, A3, A2, A3, A1 with 7pin 25cm female to female cable as the following photo shows.
(18)Fix upper chassis to lower chassis with 6pcs M3*10 hex screws.
(19)Install 4 wheels onto the motors with 4pcs M2.2×22 screws or M2.5X20 screws.
Special Note: Some user might found that the M2.2 screw might be too short to fix the wheel to the car, if this is your case, please contact OSOYOO support (support@osoyoo.info) and ask for free new M2.5×20 screws
Note: there are two types and to arrange them so the rollers point toward center of car when viewed from above.
Now hardware installation is almost down. Before we install 18650 batteries into the box, we need burn the sample code into Arduino First.
Step 2: Circut Connection
Step 1: Install latest Arduino IDE (If you have Arduino IDE version after 1.1.16, please skip this step). Download Arduino IDE from https://www.arduino.cc/en/Main/Software?setlang=en , then install the software.
Step 2: Download https://osoyoo.com/driver/mecanum_acrylic_chassis_v2/mc-lesson1.zip, unzip the download zip file mc-lesson1.zip, you will see a folder called mc-lesson1.zip.
Step 3: Connect Mega2560 board to PC with USB cable, Open Arduino IDE -> click file -> click Open -> choose code “mc-lesson1.ino” in lesson1 folder, load the code into arduino.
Step 4: Choose corresponding board/port for your project,upload the sketch to the board.
Note: If the car runs from USB (ie wheels turn when off ground) but it does not work when the USB is disconnected and the batteries correctly inserted, check the double driver Y board switch – it was probably knocked and is up. It can be pushed down with a screwdriver without taking top and bottom apart.
Step 3: How to Play
Disconnect Arduino from PC, put battery into battery box. When you put the car on the ground and turn on the switch on OSOYOO Uart WIFI shield V1.3 and the switch on battery box if you install battery box for 18650.
The car should Forward→Backward→Left turn→Right turn→
Right Parallel Shift→Left Parallel Shift→
Down Left Diagonal→ Up Right Diagonal→
Up Left Diagonal → Down Right Diagonal, then stop.
