Introduction: VSS Vintorez
Hey everyone this is my first instructable! (Confetti falls)
This is my Knex version of the VSS Vintorez sniper rifle. After a long time trying to make my own guns, I decided to make models instead. I saw this gun in Metal Gear Solid 4 and I liked how it was different from other guns. The VSS is a sniper rifle that is unique because it has a built in silencer. Yea, it's cool.
As for the Knex version, I used a slingshot system that throws the bullet. I used slingshot because then the gun would be silent, just like in real life. Subscribe if you want to. Thanks!
Pros:
-True Trigger
-Pieces don't break
-Power, 120 feet, but according to Viccie.B1993 it can go 160 feet. Silentassasin21 said with killerk's bullet, he got it to go 235 feet!
-Accurate
-Looks
Con's:
-Uses moderate pieces (In my opinion)
-The rubberbanbs I use might be expensive, but if you think about it, it isn't that much.
Thanks to:
-Barrax for his plentiful criticism on making my gun look better. :D
-I Am Canadian for his criticism.
-Viccie.B1993 for the firing system.
-LordSnipe for his magnum bolt.
Pros:
-True Trigger
-Pieces don't break
-Accurate
-Looks
Con's:
Thanks to:
Step 1: Parts List
Here is the parts list. It would be pretty disappointing to build the whole gun and then figure you don't have enough pieces. The picture following the wheel will match the parts list. Example: Since the blue rods are 3rd on the parts list, then they are the third picture after the wheel. You do not need the wheel.
Remember: Colors vary in the world of Knex so look at the pictures if you have trouble.
Rods:
-Small black/green rods: 137
-Gray/Black rods: 178 gray-150, black-28
-Blue rods: 56
-Medium dark gray rods: 6
-Green/ Red rods: 1
-Black/ Gray rods: 2
Connectors:
-Gray, one-way connector: 13
-White, two-way connector: 3
-Dark gray, right-angle, three-way connector: 46
-Green, 135 degree, four-way connector: 6
-Half-moon, five-way connector: 157 white-131, bronze-26
-Brown, straight, two-way connector: 56
-Blue, snowflake 3D connector: 14
-Black snowflake connector: 32
Odd Preces:
-Blue spacers: 8
-Gray spacers: 10
-Orange track connectors: 4
-Black gear knob: 1
-Tan connector clip: 1
-Blue connector clip: 1
-Multiple angle, blue/black connector sets: 4
-Y connectors: 39
Other:
-#64 Rubberbands. Here's the link. Another one, cheaper I found is here.
-Tape
Rods:
-Blue rods: 56
-Green/ Red rods: 1
Connectors:
Odd Preces:
-Blue spacers: 8
-Gray spacers: 10
-Black gear knob: 1
-Y connectors: 39
Other:
-Tape
Step 2: Trigger Mechanism
This is the Trigger Mechanism by Viccie.B1993 that I used. I like this mechanism because it so versatile and reliable.
Pictures:
1-3. What you are building.
4. Build this. Yes it is a Y connector.
5. Wrap as much tape aroud the connection point as you would like, then put a rubberband around it. This is so the y connector doesn't come off.
6. Add.
7. Add.
8. Add.
9. Add.
10. Add.
11. Add. Put the blue rod into the brown connector we just put on. Then add the half-moon connectors.
12. Make this.
13. Add.
14. Turn the mechanism around 180 degrees and add.
15. Do the same to the other side.
16. Make this. This is one of the connectors for the scope.
17. Insert as shown.
18. On the inside, add a Y connector pointing down to fasten the gray connector.
You're done!
Pictures:
6. Add.
7. Add.
8. Add.
9. Add.
10. Add.
12. Make this.
13. Add.
You're done!
Step 3: Barrel
This barrel is based off of KillerK's, but it is also very generic. To make it my own and for stability, I added alternating brown connectors in the middle. You can make the barrel as long as you wan't to, but if you build it my way then it will be more realistic
Pictures:
1-2. What you are building.
3. First layer. Those are blue connectors in the half-moon connectors.
4. Second layer. Basically the opposite of the first. Like me, you don't have to add the small black connectors to connect the half-moons. I did it because I was low on pieces.
5. Second layer still, but there are 4 Y connectors alternating on the blue rods. There is a better picture in picture 10.
6. Second layer. The other side of the barrel.
7. Add brown connectors on the blue rods as shown.
8. Add another layer of brown connectors, but alternating with the third layer.
9. Fifth layer just like the second, including the Y connector.
10. What the Y connectors should look like.
11. The other side of the fifth layer.
12. Sixth layer. Same as first layer.
13. Add to the black snowflakes.
14-20. Other views of the final product.
Pictures:
Step 4: Handle
Well...um... this is the handle. Not much to say except look at the pictures.
Pictures:
1. What you are making.
2. Make.
3. Add second layer.
4. Add third layer.
5. Add fourth layer.
6. Add fifth layer.
7. Add sixth layer of what is shown.
8. What you are making.
9. Make.
10. Make.
11. Add.
12. Add to back.
13. Add.
14. Fasten on the inside with Y connector.
15. What you are making.
16. Make.
17. Add.
18. Add.
19. Add.
20. Add.
21. Add.
22. Make.
23. Add.
24. Showing connection points.
25. Connect.
26. Add the two dark gray rods.
27. Add the outside hooks.
28. Add the Y connectors on top.
29. Click the half-moon connectors up.
Pictures:
2. Make.
4. Add third layer.
6. Add fifth layer.
9. Make.
10. Make.
11. Add.
12. Add to back.
13. Add.
16. Make.
17. Add.
18. Add.
19. Add.
20. Add.
21. Add.
22. Make.
23. Add.
25. Connect.
Step 5: Magazine
This is the magazine and the underside or the gun. Follow the pictures. Just to make a point, the magazine is not real because this is a slingshot gun.
Pictures:
2. Make.
3. Add.
4. Make.
5. Add.
6. Add.
7. Add.
8-10. What it should look like.
11. What you're making next.
12. Make.
13. Add.
14. Add.
15. Add.
16. Add.
17. Add.
18. What you are making.
19. Make.
20. Add.
21. Add.
22. Add.
23. Make.
24. Add.
25. Get these two parts.
26. Connect.
27. Get these two pieces.
28. Connect.
Pictures:
2. Make.
3. Add.
4. Make.
5. Add.
6. Add.
7. Add.
12. Make.
13. Add.
14. Add.
15. Add.
16. Add.
17. Add.
19. Make.
20. Add.
21. Add.
22. Add.
23. Make.
24. Add.
26. Connect.
28. Connect.
Step 6: Stock
This is the stock. I used the bronze half-moon connectors to make it look like wood, but you don't have to use them if you don't want to.
Pictures:
2. Make.
4. A close up of what the the strut in the stock should look like.
5. Add third layer.
6. Add fourth layer, same as third.
7. Add fifth layer, same as second.
8. Add sixth layer, same as first.
9-12. What it should look like.
Pictures:
2. Make.
5. Add third layer.
Step 7: Scope
This is my scope for the VSS. You can design your own, but make sure it fits into the grey and brown connectors that fasten onto the gun. For advanced Knexers, go to pictures 25-27 and build from there if you can.
EDIT: I added a down the scope view. All I did was make a basic model and show you the shape. The only difference is to just imagine more connectors between this piece. This is picture 28.
Pictures:
2. Make.
3. Add.
4. Make.
5. What you are making next.
6. Make.
7. Add.
8. Add.
9. Another angle of what it should look like.
10. Add orange track pieces. You can subsitutue them for what ever you like, such as Y connectors.
11. Make.
12. Get.
13. Add.
14. Get.
15. Connect.
16. Get.
17. Connect.
18. Get four black rods, they can be subsitutued for gray though.
19. Add.
20. Another look of what it should look like.
21. Make.
22. Attach.
23. Get.
24. Connect.
25-28. What the final product should look like.
Pictures:
2. Make.
3. Add.
4. Make.
6. Make.
7. Add.
8. Add.
11. Make.
12. Get.
13. Add.
14. Get.
15. Connect.
16. Get.
17. Connect.
19. Add.
21. Make.
22. Attach.
23. Get.
24. Connect.
Step 8: Stock Connector
This is the connector that connects, of course, the stock to the body of the gun.
Pictures:
2. Make first layer.
4. Add third layer.
5. Add fourth layer, same as third.
6. Add fifth layer, same as second.
7. Add sixth layer, same as first.
8. Another view of what it should look like.
Pictures:
4. Add third layer.
Step 9: Top Rail
This the the top part of the gun that snaps into the Y connectors on the barrel and handle. I'lln make the assembly more clear in the Assembly step. Yes, this is a very easy step.
Pictures:
2. Make.
3. Add the blue rod.
Pictures:
2. Make.
Step 10: Assembly
After all that hard work, now it's time for some progress to be showing. Follow the pictures.
Pictures:
1. Barrel and Trigger Mechanism.
2. Connect.
3. Another view.
4. Add Handle.
5. Connect.
6. Add Magazine.
7. Connect as shown.
8. Connect blue snowflake.
9. Connect as shown.
10. Add Stock.
11. Connect.
12. Add Stock Connector.
13. Connect.
14. Add top rail.
15. Connect.
16. Add Scope.
17. Connect.
18-23. What your final gun should look like.
Pictures:
2. Connect.
3. Another view.
4. Add Handle.
5. Connect.
6. Add Magazine.
10. Add Stock.
11. Connect.
13. Connect.
14. Add top rail.
15. Connect.
16. Add Scope.
17. Connect.
Step 11: Ammo
You can use whatever ammo you would like, but I found a way to make some removeable fins. Follow the pictures if you want.
-Thanks to LordSnipe again for the magnum bullet! Here's the link.
Pictures:
1. Types of ammo
2. Removable fins, what you are making.
3. Wrap a piece of tape tightly around the rod.
4. Take another piece of tape and fold it in half and hold it like this.
5. This is how you set it on the tape. I used a red rod with no tape to show you how it fits on.
6. How your first fin should look.
7. Add as many fins as you want, but this is what it should look like when removed from the rod.
Pictures:
1. Types of ammo
Step 12: Rubberbands
Follow the pictures on how to make and place the rubberbands.
Remember: Results may vary depending on what rubberbands you use. If you use the rubberbands that I described it the Parts List, then you might have similar results like me.
Pictures:
1. Make a string of three rubberband or however many. For my rubberbands, use three.
2. Wrap a single rubberband around the trigger. Make sure the force of this rubberband is greater than that of the ammo because it holds the ammo back from going forward.
3. Another look.
4. Wrap around the end of the gun like this. For me, I make the rubberbands go on the outside of the two "bars."
Pictures:
3. Another look.
Step 13: Loading and Firing
Follow the pictures and then you can show others why they should fear you!
For a hilarious joke, see the last step.
Pictures:
1. Snap the bullet into the Y connector.
2. Pull the rubberband and hook it into the tan clip.
3. Pull the trigger and instant destruction!
Pictures:
Step 14: You're Finished!
Hey your done! Have fun with my VSS. Comment on my Orangeboard if you have any requests on the next gun I should build. Don't forget to subscribe.
DISCLAIMER: I AM NOT RESPONSIBLE WITH ANY DAMAGES PRODUCED BY THIS GUN.
I don't wan't to really end on a bad note so here's a joke.
Q: What do you call a mint that tastes bad?
A: A disappointmint
HAHAHAHAHAHAHA!!!!!!!
A: A disappointmint
