Valentine's Day Dangling Earrings
Intro: Valentine's Day Dangling Earrings
These are fast and fashionable dangling earrings - make as a gift for you Valentine!
STEP 1: Materials
What you'll need:
20 gauge silver or gold wire
28 gauge matching wire
jewelry pliers
2 matching head pins
4 small pink beads
4 small red beads
2 matching earring hooks
STEP 2: Top Loop
Cut a 5" peice of 20 gauge wire and center your needle nose pliers in the middle. Make a loop in the center and with your flat nose pliers, press down right under the loop. Then, with 28 gauge wire, wrap firmly around right under the loop and cut off extra wire.
STEP 3: Ric-Rac Pattern
With your flat nose pliers, bend both sides of the wire into three diamond-shaped spaces, as shown in the pictures. When you get to the bottom, twist both pieces of wire together, then wrap one piece around your round nosed pliers to form and loop. Wrap the other piece of wire around under the loop to secure.
STEP 4: Adding Beads
Cut a 5" peice of 28 gauge wire and wrap the end around under the top loop. Add a bead and wrap the wire around 2-3 times in between the two spaces, so the bead fits inside the first "pod". Continue doing this in each space. Wrap the extra wire around under the bottom loop to secure.
STEP 5: Extra Dangling Bead
Place a bead on a head pin, and using your round nose pliers, form a loop right above the bead. Cut off the extra wire. Open the loop and place on the bottom loop of the earring. Close the loop tightly. Then open the loop on an earring hook and attach to the earring. There, your earring is finished! All you need to do now is make another one. :)
STEP 6: Finished!
Open the loop on an earring hook and attach to the earring. Now your earring is finished!
2 Comments
Penolopy Bulnick 8 years ago
Super cute :D
kruth1 8 years ago
Very pretty and can be made in any colors, too. Thank you!
