Vampire-Hunting Gun Prop With UV Bullets
Intro: Vampire-Hunting Gun Prop With UV Bullets
For Halloween 2008, I was a vampire bounty hunter that specializes in killing my own kind. I traveled to New Orleans -- which is sort of vampire mecca -- and the hunting was spectacular. Here, I document how I made my Vampire-Hunting Handgun with UV bullets and cartridge prop, which was inspired by the UV-weapons in the movie Underworld.
STEP 1: Start With a Suitable Toy Gun
I chose a Nerf N-Strike Maverick, which is quite an amazing toy for only $8.
STEP 2: Disassemble the Gun
Disassemble the gun and figure out how to fit some lights inside.
STEP 3: LEDs and a Battery in the Barrel
Putting the LEDs and a battery into the barrel allowed the barrel to still rotate and advance when you pulled the trigger. I cut slits in the side of the barrel with a Dremel to allow light come out of the sides, in addition to the front. I had to cut away portions of the barrel to get everything to fit.
I soldered six white LEDs in series with a resistor, switch, and a 9 volt battery clip. Each LED was then hot glued into position within the barrel.
STEP 4: Cut the Gun to Fit a Glow-Stick
Cut holes in the handle so that a glow-stick fits into the gun like a cartridge.
STEP 5: Spray Paint
Spray paint the body black and the trigger and other highlights silver. I also did a light coating on the inside, so no yellow would be visible along the seam of the body.
STEP 6: Dry Brush Silver
Inspired by many of gmjhowe's paint-jobs, I dry-brushed silver to give the gun a worn look. I found it most effective to spray silver paint into a small puddle, dip a paintbrush in the puddle, then paint newspaper until I was barely transferring any further paint. Finally, I would use the almost-dry paintbrush to highlight the edges of the gun, and any other exposed surfaces that would likely be worn.
I also sanded off the Nerf logo on the gun's slide.
STEP 7: Reassemble the Gun
Note how the barrel still rotates.
STEP 8: Hunt Vampires
Crack the glow-stick, switch on the LEDs, and hunt down some vampires.
74 Comments
BstnRedSox3312 15 years ago
lasr1 14 years ago
Kindhamster 14 years ago
OH SNAP!!!
eulaliaaaa! 13 years ago
peyton14 11 years ago
Garrus 11 years ago
Link: http://www.youtube.com/watch?v=nq3t_etZ8Og
moviefreak54 11 years ago
Cyclone2019 11 years ago
clark981 12 years ago
Crus5ver 12 years ago
i even paint the darts too!
i have a nerf recon and it was broken and i fixed it somehow
then i have to paint it
it's colours just look like yours
SteampunkManiac 12 years ago
tgriner1 13 years ago
pieman12 12 years ago
SHIFT! 13 years ago
goatgirly 15 years ago
ewilhelm 15 years ago
http://www.8-legs.org/ewilhelm/events/2003%20events/2003-10-17%20haunted%20dentist%20office/
lil larry 13 years ago
imrobot 15 years ago
