Introduction: Home Made Swing
Hello, for school, I was assigned to make a homemade swing.
Follow the steps and come to the same result.
Step 1: Material
To make this swing, you will need 2 things:
- wooden beam (+- 80cm)
- 2x rope (+- 8m)
- 1x little rope (+-2m)
- bag
- weights
Tools:
- Drill
- Saw
- File brush
- Knife
Step 2: Drill
Drill 4 holes (diameter 11) in the wooden beam (2 each side) on a distance of 3.5cm and 7cm
Step 3: Larger the Outer Holes
Larger the outer holes (diameter 30) and drill 1 cm deep.
Step 4: Slot
Saw from the side a slot (1 cm thick) up to the first hole.
Step 5: File Brush
Work the slot with a nice file brush
Step 6: Big Rope
Stick your rope through the small hole and make sure it does not come loose.
at the other side of te rope, create at different locations (25cm apart) nodules.
Step 7: Little Rope and Bag With Weights
Fill the bag with weights.
Nodule small rope around the bag and close it.
