Introduction: Variations of Two Rings Joined Together
(Note: If you don't know how to draw the original, click here to find out.)
If your friends are bored of the two rings trick and you need something new-FAST-you have come to the right spot. Some twists of the classic which definitely going to amuse friends.
Step 1: I Just Drilled a Hole............
Easy enough. Just make the starting square a circle.
Step 2: The Triangle
Just use a triangle. You get VERY funny results!
Step 3: Pulled Tight
You can't rattle these! To give it the impression that it is pulled tight don't draw the "speedbumps".
Step 4: Heads Up!!!
Draw two rings and then add a face and some feet. NOT antennae, FEET!!
Step 5: Squared
You draw it normally, but every curve becomes a square.
Step 6: Comment and Share!
Thanks for reading this instructable! Please check out my other instructables for other great things.
