Vegepod (1 Metre Square Gardening)
1,416
28
Introduction: Vegepod (1 Metre Square Gardening)
About: I am a Marine Engineer in the RNZN (41 years done in various navies) and am looking forward to retirement!!! so I can do more messing about with tools
My wife wanted a Vegepod (see pic) as we have real difficulty growing lettuce etc these are really expensive (about $450NZ with the stand), well I thought I can do better than that.
I've estimated costs where I got free stuff
Materials and Tools90x 32mm decking timber
plastic trays
plastic conduit plus fittings
screws 60mm
bracket screws
hinges
handle
hasp and staple
wheels
shade cloth
drill
circular saw
chop saw
screwdriver
rule
clamps
Step 1: Tray/Water Reservoir
The basic idea of the Vegepod is that it is at a convenient height, and has a water reservoir so you don't have to constantly water, it is also protected from birds and mobile so that you can move it out of the sun to prevent crops "bolting" to seed
To start I had a bunch of the grey trays which were free (my favourite price) from work, they were supplied with some new desks but made the leg space too small for people to use. If I had to buy them I guess $10 each I laid 4 out and put my decking around them to get my basic measurement
Step 2: Base
Once I had got my basic measurements I screwed the frame together and then put in a weatherproof ply base.
I got this free from a neighbour as it was the bits he had cut out from windows when building his house but probably another $10 worth I bopped a bunch of drainage holes through it
Step 3: Legs and Soil Area (upside Down)
I then cut 4 legs at 900mm (convenient height) and made 2 more squares to contain the soil, and screwed everything together with 60mm screws
Step 4: And Turned the Right Way Up
Once upright I added a bottom frame to stabilize and use for a shelf and chopped the handles down to length
Step 5: Bottom Shelf and Top Frame
To strengthen the whole structure I added a bottom shelf and made a hinged frame for the top cover (I ripped some of the decking in half)
the hinges were free from a dismantled crate but lets say $4
Step 6: Handles and Wheels
I envisaged this being moveable like a wheelbarrow so shaped the handles to a convenient shape.
I found 2 wheels in a skip at work (they were throwing them out as the new inner tubes didn't fit!!!) A bit of jiggery pokery drilling the holes for valve stems etc and they were good to go, lets say $15 if I had bought them, I had a couple of 12mm dia bolts, nuts and washers salvaged from a broken gate but probably another $8 worth
Step 7: Front Wheels
Wasn't going to have front wheels but my wife said it was too heavy for her to easily manoeuver, so added 2 front wheels, these were $10
Step 8: Cover the Frame
I used some frost cloth to cover the frame ($5 a roll) and stapled it in place and fastened the top back on
Added a handle (free off a packing case) so $2 and a hasp and staple to keep it shut
Step 9: Top Cover
I had PVC some conduit left over from wiring my shed $18 per length and bought 4 elbows and 2 tee pieces to make a frame - total $10
Filled the conduit with hot water to help it bend and secured it to the top frame
Step 10: And in Position
So there it is
Lined the soil area with weedmat and filled with compost
Then put where she who must be obeyed wanted it and planted it out
Costings
30m of Decking at $2.44 a meter = 73.20
4 trays $40 (free)
Plywood $10 (free)
Hinges $4 (free)
Front Wheels $15 (free)
Back Wheels $10 (free)
Coach Bolts $8 (free)
Conduit and fittings $28 (free)
Screws $20
Handle $2 (free)
Frost cloth and weedmat $5
Hasp and Staple $5
Total $220 NZ If I bought everything
(US$146, 123 Euros,110 GBP, AU$201)
The actual cost accounting for all the free bits was $111NZ
Woodworking Contest
Woodworking Contest
Be the First to Share
    • Make it Real Student Design Challenge #3
    • Arduino Contest
      Arduino Contest
    2 Comments
    buck2217
    buck2217
    Reply 3 months ago
    Thanks
