Vehicle Intelligent Distance Avoidance Sensor KWh Meter Cloud Enabler
Intro: Vehicle Intelligent Distance Avoidance Sensor KWh Meter Cloud Enabler
Yes, achieve actionable insights from your old kWh meter by putting it's big data in the cloud.
STEP 1: What You Will Need
1 Arduino uno (about 3 dollars at Aliexpress)
3 Female to male jumper wires (10 cents)
1 Vehicle intelligent distance avoidance sensor (50 cents)
3 pieces of tape
STEP 2: Technical Stuff
Connect gnd to gnd, vcc to 5v and out to analog pin 4.
And then, upload the code below.
It's unnecessarily lengthy, yet readable.
int sensorpin = 4; // analog pin for vehicle intelligent distance avoidance sensor output
int val = 0; // variable for sensorpin output
void setup() {
Serial.begin(9600); // fire up the serial monitor!
void loop() {
val = analogRead(sensorpin); // read vehicle intelligent distance avoidance sensor output
Serial.println(val); // send vehicle intelligent distance avoidance sensor output to your cloud enabled device
STEP 3: Getting It to Work
Tape your vehicle intelligent distance avoidance sensor to your kWh-meter. Handle your tape carefully, you only have three pieces.
Keep fiddling with the vehicle intelligent distance avoidance sensor until the LED of the vehicle intelligent distance avoidance sensor sings in tune with the black mark on the spinning disk.
You're done.
