Introduction: Velcro Face Mask
This is a Velcro strap face mask with PM2.5 filter pocket.
-LINK to Pattern: https://www.properfitclothing.com/product-page/fac...
-LINK to Bias tape folder kit: https://goo.gl/E4X5go
-LINK to Bias Tape: https://goo.gl/rtMLte
-LINK to Industrial Bias Tape Attachment: https://amzn.to/2Ua3It3
-LINK to Fabric: https://amzn.to/2lNrnly
-LINK to Lining: https://amzn.to/2QkCcb8
-LINK to Velcro: https://amzn.to/2V9GFQY
-LINK to PM2.5 Filter: https://amzn.to/2WjyP8k
-LINK to Coated Wire Tie: https://amzn.to/2wfnmvA
-LINK to Twist Ties: https://amzn.to/2V81bB8
Step 1: Gather Supplies
-Fabric outer layer: .25 yards (tightly woven cotton or nonwoven material)
-Fabric lining: .25 yards (non stretch soft cotton)
-Bias tape: Extra wide
-Velcro: 10 inches
-PM2.5 filter
Step 2: Cut Pattern
-Front main panel: Cut 1-2 depending on how many layer you want for protection. This can also be determined by how loose your fabric is. Just keep in mind the more layer the more protection.
-Front and lining bottom panel: Cut 1 outer layer fabric. Cut 1 lining fabric.
-Center lining panel: Cut 1 lining fabric
Step 3: Hem Lining
-Mark the hem lines onto the lining panels.
-Both sides of center lining panel and only the inside edges of the lining side panels.
-Roll over and pin edge.
-Sew at .25 inch seam allowance.
Step 4: Lining Peak
-Place the right sides together.
-Sew as close as you can to the edge.
-Trim the point close to the seam.
Step 5: Front Main Panel Peak
(Repeat previous step on the front main panel)
Step 6: Add Bias Tape
-You can use made bias tape, make your own bias tape, or bias tape attachment. All methods work.
-Place the wrong sides of the outer layer and lining together.
-Add bias tape to the top straight edge of the bottom main panel.
Step 7: Add Twist Tie
-Slide the twist tie or other bendy metal object into the bias tape.
-Make sure the twist tie is centered in the bias tape.
Step 8: Assembling Panels
-Place the wrong sides of the Center Lining and Front Main Panel together.
-Line up the bottom seams and top notch.
-Place the Bottom Main panel on top of the lining with right sides together.
Step 9: Bias Tape Back Sides
-Bias tape only the back sides of the Front Main Panel.
Step 10: Adding Velcro
-Cut 4-5 inch strip of Velcro.
-Velcro will overlap so one strip will go on the outside and one on the inside.
-Place in the back center of the Front Main Panel.
-Sew along the outside of the Velcro.
Step 11: Bias Tape Top and Bottom Edge
-Add bias tape to the top and bottom edge.
-Leave .5-1 inch at the start and end of each edge.
Step 12: Sewing Off Ends
-With the remaining bias tape. Fold over the ends towards the inside.
-Tack stitch each corner.
Step 13: Add PM2.5 Filter
-Last step is to add the PM2.5 filter to the inside pocket.
-If you are having trouble finding the filters. Here is a link to making your own from household materials : https://youtu.be/ySgsARkOxkM
