Introduction: Vending Machine Using an Arduino
This is how you can make your arduino powered vending machine.
Step 1: Sketches
Draw out what your vending machine will look like including, measurement to scale.It should look something like this.
Step 2: Make the Box
Step 2 is making the box to put the vending machine in using the sketches to help you.
Step 3: Set Up the Arduino
Once you set it up it should look something like this.
Step 4: Put the Arduino in the Box
Once you have the arduino set up code it make the arduino angle to 75 and 175 degrees. You can make the speed however fast or slow you want. Then drill a hole for the button and the place the arduino in the box and then manage the cables so they do not get in the way.
Step 5: The Front
Drill 2 large slots in the front for the slide out and the window put everything together ,then you are done.
