Introduction: Vernier Caliper
About: Interested in automation and CNC machine.
It's a cheap vernier caliper for home use.
Don't worry it's exact. (:
What we need :
MDF 3.0 mm sheet. about 30×20 cm
(2) M3 × 6 mm bolts
(4) M3 × 9 mm bolts
(6) M3 nuts
Step 1: Edit Print File
You can download .dxf file and add numbers.
Sorry I don't know how can I do it in Solidworks. |:
Notice : It has two veriner if you want to use both vernier at the same time should edit file.
Step 2: Glue the Nuts in Holes
Step 3: Assembly
I hope picture is clear enough.
Step 4: Calibrate
Tight the screws but not very tighten.
Close caliper jaws and set zero line of verniers in the front of zero line of ruler.
Tight the screws. (:
It's ready. enjoy!
