Introduction: Very Basic Batch Tutorial
If you already know the essentials of Batch the you DO NOT need to read this instructable continue to Not So Basic Batch Tutorial.
NOTE!: Whenever something is in quotation marks ("example"), do not include the quotation marks (if you see that you must just type: example)
Step 1: So, What Is Batch
For those who don't know, a Batch file is a text file containing a series of commands to be executed by Command Prompt (CMD). When a batch file is run, CMD reads the file and executes its commands.
To open your CMD, click START > RUN > type "CMD" > OK
(some of you may need to type "CMD.EXE")
(or you can click START > ALL PROGRAMS > ACCESSORIES > COMMAND PROMPT).
Step 2: Now What?
These are some VERY basic commands you need to know:
(please try out some of these commands in your CMD).
@echo off - This gets rid of that "c:\documents...etc"
echo - This displays a message, (e.g "echo hello" = "hello") because if you type "hello" into CMD it will interpret "hello" as the command
cls - Clears the CMD of all text.
color - Changes the color (type "help color" for a list of colors).
goto - Goes to a particular word in your text (you will learn more later)
pause - Pauses the command prompt and displays the message: "Press any key to continue..."
and there are a few more we will learn about later.
Step 3: But What If I Want to Run a Lot of Commands.
That is where BATCH comes in.
Try copying this into your notepad (NOT Microsoft Word) and save as BatchFile.bat
Notepad is in accessories
NB: You must save it as .BAT or it won't work.
P.S (copy BETWEEN the stars, don't include them)
echo If you type echo before a sentence it displays it as a message!.
echo Wow, thats pretty cool!
copy that into notepad and save as .bat
Double-click on the .bat file...cool hey!
NOPE. It went too fast...try adding a pause at the end, like this:
PAUSE
There it worked, but its quite hard to read with all those file paths in the way...
thats why we add an "@echo off" to the top;
like this:
@echo off
PAUSE
There! that worked perfectly, you have now written your first batch file!
PAUSE
like this:
@echo off
PAUSE
Step 4: The GOTO Command
Now we will learn how to use the GOTO command.
The GOTO command jumps to a certain part of your text.
Example:
if you type "goto fish"
then it will goto the place that you have typed in ":fish"
NB: you must always have a colon (:), before a word that is going to be GOTO'ed
Example:
you know the drill, copy into notepad and save as a .bat file.
(do not copy the stars)
@echo off
:fish
echo This is only one message being repeated over and over; Press Ctrl+C to stop
goto fish
*Note: Ctrl+C is the universal way of stopping a batch file
What happened was that every time it typed "Press Ctrl...etc"
the GOTO command made it go to the top.
Pretty nifty eh?
Example:
Example:
@echo off
:fish
goto fish
Pretty nifty eh?
Step 5: The START Command
The START command starts something.
Not much to explain here.
For example:
open your CMD and type:
"start www.instructables.com"
This opens your default explorer and goes to the Instructables site.
OR
"start itunes"
OR
You can also open files or folders:
"start desktop\foldername
**NOTE: To access a file\folder which has spaces in the name, put quotation marks (" ") around it.
e.g start "C:\desktop\folder name"
For example:
OR
"start itunes"
OR
Step 6: Done
Well done! Please continue to the Not So Basic Batch Tutorial for some cool Batch commands!
If you want to try something offline, I recommend getting Learn Batch File Programming! by John Albert, really simple, easy to follow and great if you want to get better!
