Introduction: Very Powerful Knex Hand Gun (UPGRADE)
This is not a copy of k'nex gunman's gun. it's an upgrade. It's even more powerful and accurate, New handle design and much easier to pull the firing pin back! And the trigger automatically clicks into place when you pull back the firing pin! It fires red and gray rods but i recommend Red rods because its lighter and flies much further than gray rods. And this is my first instructable.
Step 1: Build the Handle
The handle is a much better handle the original one.
6 Green Connectors
11 White Rods
2 Light Gray Connectors
3 Blue Spacers
Step 2: Firing Pin
The firing pin should have some tape on it or it will break off.
1 yellow rod
1 orange connector
1 blue rod
1 blue spacer
some tape
A Sharpener
Step 3: The Barrel
This is the most important part of the gun!
5 Light Grey Connectors
1 Ball joint Connector (Female)
3 Grey Connectors
2 yellow rods
1 "Y" Shape connectors
1 green rod
1 orange connectors
Step 4: Sniper Mount
The Sniper Mount is for top accuracy. it is not needed but recommended for much better accuracy.
4 Green connectors
4 blue spacers
4 orange connectors
4 white rods
Step 5: Putting It All Together
In this step you will put everything together!
Step 6: Elastic Bands
You should use 2 very strong rubber bands but you can use normal ones and there is one another normal elastic band so that the trigger automatically click into place when you pull back the firing pin.
Step 7: Bullets and How to Load and Fire
You can use red or gray rods to fire but i would choose a red rod because it is lighter and flies much faster and longer than a gray rod. To load simply pull back the firing pin until the trigger locks in place and insert a red or gray rod until it clicks into the ball joint and pull the trigger and ... FIRE!
