Introduction: Very Simple 9v Tesla Coil
Hello friends, my name is Deepesh. We are going to make a very simple tesla coil that can be operated by a 9v battery. This is my first Instructables so if I made any mistake then let me know
Step 1: Gathering the Material
2.small diametre pcb pipe or any round pipe on which you can coil the wire it can be of any material other than iron
3.transistor 2n2222a
4.22kilo ohm resistence
5. 9v battery and its cap
6. a switch
7.a base
8.some wires
9.soldering equipments
Step 2: Making the Coil
Step 3: Joining With Transistor
Step 4: Adding the Switch
Step 5: Adding the Secondary Coil
Step 6: Adding Power Supply
Step 7: Testing
Step 8: How It Works
The Tesla coil works with the principle of Electromagnetic
Induction. According to this, when a conductor is placed under a varying magnetic field, a small current will be induced inside the conductor. For a Tesla coil, this conductor will be called the secondary coil and the varying magnetic field will be produced by the primary coil by passing an oscillating current through the primary coil. A primary coil will have an oscillating current and hence will produce a carrying magnetic flux around it. Now, this coil is wound around the secondary coil, and hence according to the law of electromagnetic induction, a voltage will be induced in the secondary coil. Since the number of turns in the secondary coil is very large than the primary coil, this voltage will be a very high voltage and hence this coil will have a very strong electric flux around it that is powerful enough to glow normal CFL bulbs and is used in Wireless Power Transmission.
