Introduction: Very Simple DIY Table Saw
This homemade table saw is made out of a track saw
Step 1: The Idea
a track saw has a rail
but if you turn the saw upside down
the rail becomes a very handy cross cut sled
Step 2: What Can You Expect?
with a special clamp , that fits into the rail
you have a very clever crosscut sled
you can cut every angle you want
and with a board, as a table saw fence, you can cut all of your stripes
for bigger parts, you can easily uninstall the saw
and use it as a normal track saw again
Step 3: Overview
you need only to build
- a jig for the deep setting,
- a frame for the saw and
- a trigger for the switch
Step 4: How to Built the Frame
The frame is made out of two boards
in the first picture, you see a little nose on the saw
this nose disturb the fit of the boards
so I cut them out with a jig saw
Step 5: Set Up
I screwed down one board on my table,
I placed the saw in position
and then I screwed down the second board
Step 6: Secure the Saw
this saw has two holes on his plate
but unfortunately this holes are out of the range of the boards
so I screwed two blocks of plywood under the boards
and I could fix the saw with two screws
Step 7: Prevent the Rail for Tillting
This rail has a second slot on the back
I used this to secure it in place
I drilled two holes, threaded them and screwed to bolts in
Step 8: The Trigger
a little clamp, made out of 6 mm Plywood
hold the switch in place
for work with the saw you need an outlet with a switch
Step 9: The Deep Adjustment, Step 1
My saw has a hole in the handle
in this hole fits perfect a 6 mm threaded rod
Step 10: The Deep Adjustment, Step 2
this threaded rod goes through a slot of a little board
made out of 4 mm plywood
Step 11: The Deep Adjustment, Step 3
to screw on this board, it was necessary to drill and thread a new hole
first I thought, I can use the existed hole above
but this is to high, and it disturbs the saw to tilt it to 45 degrees
Step 12: Supporting Boards
my rail is 12 mm high
therefore I screwed two 6 mm boards of MDF on the left side
and two of them, glued together, on the right side
but on the right side, I made a cut with the saw so
the saw blade and the riving knife comes all the way through
Step 13: The Result
Instead of thousand words, please watch the video
If you use a mobile device, use this link .
If you want to see more of my work, subscribe to my Youtube channel
