Introduction: Very Simple Remote Control Car
Guys this is to show how to make very simple remote controlled car (not wireless) but longer will be ur wires longer will be ur limit of controlling...so...first assemble material needed.....so things needed:
Pulley (make by rapping 3 coins with paper like two thinner and one broad and pasting them like broad between two thinner)
Rubber band
2*Bidirectional DC motors with switch (make ur own by https://youtu.be/SE9wQns8sjU or see step no..2 but take as longer wires as u can towards switch)
Wires (as much as u can)
A moderate not so thin not so broad piece of wood or use on ice cream stick for this
Any wooden base or make by joining ice cream sticks
2* batteries(use this in making motors by above )
4*Bottle caps or mini tyres
2*blank pen body
Glue gun or use feviquick
2*long sticks pointed at ends
An external part any on which u will stick ur controllers of left/right and accelerate /brake (example A small box)...….........…..………………….………..............................// see fig...
Rubber band
2*blank pen body
Step 1: Let's Blow This....
Now...take ur wooden base...and cut 2 portions as shown in fig ....to put pulley and in another to put motor upside down....and to put motor shaft outwards....as shown in fig....and main thing replace motor shown in fig with bidirectional motor ....I had also told that in fig......and so ..place pulley and connect motor shaft with pulley by rubber band and and pass a stick through that pulley and than place caps or tyres at both ends.....of that stick.....as shown in fig....than instead of second portion given in fig...make a small hole through which motor shaft will come out.......and stick another motor upside down as motor shaft should come outwards the hole....and take an ice cream stick and than fix that stick with motor shaft so when shaft will start stick will move like fan...than paste blank pen body below that stick....and through that pen body....pass that same type of long stick which u passed through pulley than after passing again fix another two tyres or caps at ends of this stick....than ur partially done....see all figures......and head towards next step....
Step 2: Making Bidirectional Motor
Things needed for this:
DC motor
wires
dpdt switch ( can buy from eBay)
.....,......so let's start.....name all pins like 1 ,2,3,4,5,6 as in figure than take an wire and connect like 1,6 and with another connect 2,5 and than connect two wires of DC motor one with 3 and another with 4 than connect two wires of battery with like one with 5 and another with 6 than ur done........just when u will press switch above than it will rotate and when down than polarity is reversed ......
DC motor
wires
Step 3: Finishing......
Guys than as motors contain switch and battery so put those switches away from car...and .....tape those two wires towards switches so that it behaves like one wire....use an electric tape ....and paste those batteries above car body( wooden base ) see images for concept and labelled diagram ....and head towards last step....,....
Step 4: Finishing......
Guys now...just take an external body ,i had taken small box so telling u that ...take small box and paste ur both controllers on that box....see paste ur left/right controller horizontally on box.....so than u can add details by urself and.....u cover ur wooden base of car or u can say engine of that...
.with any external body....like u can make with plastic bottle follow images ..............than after covering ......ur done......just if u have taken battery holder ...than put cells and Enjoy....................,.,,................................
