Introduction: Vibrobot With Legs
Most virbrobots have a toothbrush below the body of the vibrobot. This version uses small paperclips as ''legs'' to support the vibrobot. The disadvantage is that it may not be stable and the legs may move out of position( if you are using blutak,).
Step 1: Building the Vibrating Motor
First, get some blutack and a small, heavy object. Attach the blutak to the part of the motor that moves around and around. Then, stick the object to the blutak.
Step 2: Assembing the Vibrobot
After making the vibrating motor ( you can use those from a toothbrush), connect it to the batteries. Attach the motor on top of the batteries( you can see in the picture)
Step 3:
Now you are read to test your vibrobot. If it doesn't move even though the motor is vibrating, try adjusting the legs or try it on a different surface.
