Vintage Flash Lamp
Intro: Vintage Flash Lamp
Ever since I found my first vintage flash in a junk store I wanted to make a lamp out of one.
They are actually very beautiful objects and also now very useless. No-one would even dream of using one of these as a flash, plus the fact that finding the bulbs would be a mission in itself!
So instead of hiding it away in a draw, wanted to put it out on display for everyone to enjoy.
The lamp itself it quite easy to build, you only really need a couple of main pieces and your away. So if you would like to know how to build your own vintage flash lamp read on...
STEP 1: Similar But Different
When purchasing more of the vintage flashes I din't realise that there were different sizes! I purchased the same flash (a waltz flash) and each time ended up with smaller ones that the original I used. I decided to use these in a double lamp.
The modification is pretty much the same as the original one. The main difference with the double lamp is I wanted to hide all of the wires which I managed to do. The switch is located in the base of the lamp and I also used smaller LED globes so they didn't hang down. In the images bellow I used a larger globe
STEP 2: Things to Gather
Parts:
1. Vintage flash. I used a waltz flash - eBay
2. Microphone stand - eBay (this one is exactly the same as the one I used)
3. Bi pin light bulb (12v 20W). Type - G4. Ebay
4. Bi pin socket - eBay
5. 12v 1.5a power adapter - eBay (just copy and paste the description into eBay to find the right one for your region)
6. Toggle switch - eBay
7. Spiralled guitar amp cord - eBay
8. Various screws and bolts
9. Camera mount - see step 6 for info on this.
Tools
1. Angle grinder
2. Soldering Iron
3. Dremmel
4. Drill
STEP 3: Mod the Microphone Stand
Steps:
1. Pull apart the mike stand and clean if not new.
2. Cut down the legs. I made mine about 250mm long each.
3. Cut down both the main sections of the mike stand. It's up to you how high you want your stand to be. I wanted mine to be able to sit on a desk and not look out of place.
NOTE: If you want to use a very simple way of attaching the flash to the stand, just swap the vertical pole and the horizontal ones around. On top of the vertical one there is a male screw which will screw into the flash. Check out step 6 to see what I mean.
4. Keep all of the cut sections - you will need a couple of bits later.
STEP 4: Mod the Flash
Steps:
1. Use a dremmel to make the inside of the flash large enough to fit the bi pin light socket into it.
2. Next drill a hole into the bottom of the flash section. This is where the wires from the socket will go through.
3. Lastly drill a hole where the battery tester is (if your flash has one). The hole needs to be large enough to fit a toggle switch into.
That's the first mods that you will need to do. There is one more later on
STEP 5: Adding the Light Socket and Switch
1. Now you have a large enough hole you can add the light socket. First thread the wires through the hole that you made.
2. Next use some strong glue to hold the socket into place. Don't use hot glue as this will just melt when the ceramic socket gets hot.
3. Next add the switch. I recently found a vintage remote control plane remote which had some cool switches attached. I used one of these and attached to the body of the flash.
STEP 6: Wiring Everything Up - Part 1
Steps:
1. First you need to thread the spiralled guitar/amp wire through the mike stand. The best way to do this is to attach a long piece of thin wire to one end of the amp spiralled wire.
2. Drill a hole near the top of the main vertical section of the mike stand - this is where the spiralled wire will come out. Make sure you file the edges smooth on all holes you drill. Thread the wire through the bottom of the mike stand and bring it out through the hole. Take your time and make sure you don't cut into the rubber of the cord.
3. Next drill 2 holes in the horizontal arm of the mike stand The one closest to the vertical section of the mike needs to be about 250mm from where the vertical and horizontal are joined. The other should be about 100mm from the end Slowly thread through the wire.
STEP 7: Attaching the Flash to the Stand
Steps:
1. Remove the male screw plug from the end of the tube that you would have cut off to reduce the stand. I put the end into a vice and wiggled back and forth until I managed to remove the plug.
2. Once removed, use some super glue and jam into the horizontal end of the stand. It should be a tight fit but the glue will ensure it wont move at all.
3. Drill a large hole into the end of the flash where it used to join to the camera. If you need to enlarge this even more then use a dremmel and make the hole large enough to fit onto the screw section that you just added to the stand.
4. Your stand should also come with a female ring which I used to secure the flash to the stand. - see images below.
STEP 8: Attaching the Flash to the Stand - Alternative Way
This is another way that you can attach the flash to the stand. I have made a couple of these and this is my preferred way.
Parts
1. Screw
2. Bolt x 2
3. Female end from a camera mount. check out eBay for one of these. here are a couple of samples that i found which would work fine - here and here and here
1. First find a screw that will actually screw into the female end of the camera mount. I also had to cut down my screw.
2. Next get a bolt that will jam into the end of the mike stand. The bolt I used was a 10mm one.
3. Screw it all together as shown below. The whole thing should be tight and the camera mount shouldn't move at all. You might need to shorted your screw if it is loose.
TIP - make sure that the bolt you use is tapered as it will make it easier to add to the mike pole - see below.
4. Use a mullet and tap the end of the pipe from the mike stand until the bolt is fully inside.
5. Next drill a hole into the flash big enough to fit the male end of the camera mount in. Screw on a bolt to the end to fix into place.
STEP 9: Wiring Everything Up - Part 2
Steps:
1. Cut the spiralled wire so there is about 100mm length left.
2. Attach a terminal to the end of the wire.
3. Add the wire to the switch.
3. Cut to length the wire from the socket and attach to the other end of the terminal.
4, Hot glue down the terminal to the flash.
5. My flash had a sliding door for the battery which I was able to use to hide most of the wiring.
6. Lastly attach the 12v plug to the end of the spiralled wire. I just soldered the ends together and added heat shrink. Test by adding the globe to the socket.
STEP 10: Finished
If you have any questions - please let me know and happy making.
11 Comments
ruudcreates 9 years ago
Just added your instructable to my newest collection with upcycled desk lamps. Really loved the design. I'm currently looking for an old camera so I can build my webcam in it. When I find one with a flash light, probably will be making one of these for in the living room.
BLR_RAVI 9 years ago
ASCAS 9 years ago
Awesome you have my vote! :)
lonesoulsurfer 9 years ago
Cheers mate.
love your work by the way.
Tarun Upadhyaya 9 years ago
I love that junkbot too on the left.
Thanks Tarun.
The junkbot I made out of a sewing machine parts - Had a great time pulling them apart!
Wow...man ..sewing machine ...amazing :). May i ask you to share a closeup picture of that bot?
Here you go Tarun. Took awhile to make - a lot of trial and error!
Wow... this is just awesome. Thank you so much for sharing:). Hats off to your creativity.
amajchrzak 9 years ago
Oh my gosh, that is so beautiful. I love photography, but I black and white printing my pictures the most. I absolutely love antique photo equipment.
Cheers. I had my own dark room for many years so I know what you mean. I only recently started to go digital but I do miss the smell of developer : )
