Introduction: Vintage Microphone Hack for Rock Band
On My quest to make playing Rock Band cooler I wanted to add some extra style. There have been gutiar and drum hacks. This is a super simple mod to a cheap USB mic. The sound quality isn't greatly affected and works the same as any free Microphone that comes with a Rock Band gaming system.
This Mic won't make you sing any better...you'll just look cooler doing it.
Parts:
- Vintage Mic
- USB Mic
Tools:
- Hammer
- Saw (optional)
- Needle Nose Pliers
- Philips Screwdriver (different sizes)
- Soldering Iron (optional)
This is my first instructable so any comments on how to improve this instructable would be greatly appreciated.
Step 1: Bust Open the USB MIC
Bust open the USB microphone! (Just be careful not to damage the actual mic in this process.) Two ways to go about this:
1) Saw the thing open and pull it apart
2) I wrapped the Mic Head with a towel and took a hammer to smash the screen. The screen top just pops right off. (this is the easier method. For future Mic mods I would use this method)
Step 2: Dissassemble USB Mic Guts
Take out the guts. Do this with care as you do not want to damage the mic or the cord.
1) Pull out Mic from the top
2) Clip the white and copper cables.
3) Pull out cable, Rubber Mic casing, and Mic
4) strip some of the cord cover to expose some of the wires.
Step 3: Dissassemble Vintage Mic
Do this with care as well. Replacement parts for vintage microphones are harder to come by.
1) Locate Face Plate screws on mic Head (There should be 4 total one on each corner)
2) Unscrew connector attachment.
3) Pull out internal connectors and clip cables.
Step 4: Remove Internal Casing From Vintage Mic
Take a part the insides on the old mic once again be careful not damage any parts of the vintage microphone as parts may not be able to be replaced.
1) Unscrew internal casing
2) Pull casing out and clip cables
Step 5: Remove OLD Microphone
1) Dissassemble old casing and remove microphone. (some extra fittings that maybe there may need to be modified to create room for USB mic wires)
2) discard old Mic (or save for future projects)
Step 6: Rewire USB Mic Into OLD Casing
1) Feed USB cable through the bottom of the mic
2) reconnect the USB cable to the USB Mic. This can be done with a soldering iron but in a quick bind I just attached the cables braided them together and covered with electrical tape. This was a quick fix since I did not want to go to Radio Shack at 11:45pm.
3) fit USB mic rubber case into the plastic casing. (trim down any of the rubber casing so that it fits nicely in the Vintage Mic.)
4) Reassemble internal mic casing and mount back into the microphone.
Step 7: Reassemble Vintage Mic W/ New USB Guts
1) Screw in Microphone face with screws.
2) Plug in!
3) Rock OUT!!!! on Rock Band.
11 Discussions
4 years ago
esto es un sacrilegio... eliminar la capsula shure para poner una con conexion usb!!! por queeeeee.
5 years ago on Step 7
9 years ago on Introduction
Just wondering, does it seem like there would be any way to non destructively get to the microphone. I was thinking about ordering a little condenser mic from digikey to replace the dynamic mic in the rockband mic, but I still would like to be able to use the same case. Is there any chance of getting it open and still being able to seal it back up, good as new?
11 years ago on Introduction
Don't waste your vintage mic's if they still work! There is a kit you can buy that will take the XLR mics into the USB needed for Rockband with no dissassembly Johnny 5! Works great. I use a ShureSM57 for the game now. Sounds great!
Where can I get said kit?
http://rockbandparts.com/rbp_premium_microphone_cable.html
there you go
Thanks!
That's cool, where did you come across the microphone?
Reply 11 years ago on Introduction
ebay, or an estate sale. You can usually get a good deal since they are non-working models. All you really need is the cool looking case.
That would be a vintage style microphone? Would that not just hook-up to the USB bits?
L
Awesome! I would imagine it feels better in the hand than the plastic one.
