Vinyl Record Bookends
Intro: Vinyl Record Bookends
Why buy Urban Outfitters'vinyl bookends when you can make your own for free?
They sell these bookends online for £20.00 but you can make your own in 5 minutes with little more than boiling water.
STEP 1: What You'll Need
You will need the following:
vinyl records - scratched or simply unwanted records are easily available for free, small 7" ones will work better for smaller books
flat bottomed heat resistant container
kettle or pot for boiling water
block of wood (optional)
STEP 2: Getting Steamy
Boil some water. You'll want enough to have about an inch of water in your container.
Dip your record into the hot water. The vinyl should bend easily once it heats up.
STEP 3: Better Shape Up
You can use a piece of wood to flatten out any waviness.
If the shape isn't quite right after you remove the record from the water, simply dip it back in and try again.
STEP 4: Take Things Up a Notch
If you're not happy with the simple design of the Urban Outfitters' bookends you can change it up.
With a few cuts and another bend, I made a set of bookends out of a larger 12" LP
15 Comments
ChristianOlsen 12 years ago
lumpee 12 years ago
Tardisaholic 12 years ago
timlewisnm 13 years ago
ModMischief 13 years ago
SantaB 12 years ago
love2make 13 years ago
beckymcmath 13 years ago
follow 13 years ago
thanks!
modhomeecteacher 13 years ago
ModHomeEcTeacher
ChrysN 13 years ago
mikeasaurus 13 years ago
Maybe a new use for some garage-sale records I found recently...
