Introduction: Visualizing Humidity and Temperature in V-VAC Using Humido Wi-Fi | IoT MQTT Dashboard for Real-Time Data
About: Supercharged No-Code IIoT Platform Create, connect, and scale IoT applications in days, not months. V-VAC delivers real time monitoring, device management, and data visualization from one browser window. Wheth…
If you love building smart IoT projects, this one’s for you! In this DIY guide, we’ll create a live humidity and temperature monitoring system that uploads real-time data to the VOLKKOMMEN® V-VAC IoT Platform — a powerful web dashboard that lets you visualize, analyze, and track sensor data from anywhere.
Using the Humido Wi-Fi module and an AHT40 humidity-temperature sensor, you’ll connect your setup to V-VAC through MQTT, watch your readings appear instantly, and design your own custom dashboard with interactive widgets like gauges, charts, and thermometers.
V-VAC makes IoT simple — no complex coding or servers needed. You just connect, configure, and start watching your environment come alive online. Whether you’re an electronics hobbyist or a student exploring IoT cloud platforms, this project gives you a clear, hands-on way to understand how smart data visualization really works.
Hardware Components
  1. Humido Wi-Fi (VOLKKOMMEN®)
  2. Humidity sensor.(AHT40 Temperature and Humidity Sensor)
  3. 5V, 1A DC Power Adapter (for Humido Wi-Fi)
  4. Laptop / PC for configuration
  5. Wi-Fi Router / Access Point
  6. Screwdriver and wire stripper for connections
  7. Connecting wires
Software Components
  1. Web Browser (Google Chrome / Edge)
  2. Wi-Fi Access Credentials (SSID and Password)
  3. Network Analyzer Tool (to find the device IP optional)
Step 1: IoT Hardware Setup for Humido Wi-Fi Sensor
Power off both devices before wiring.
LED Status Indications
  1. White: Booting
  2. Cyan fading: Scanning Wi-Fi
  3. Green: Wi-Fi connected
  4. Purple: On-Demand
Step 2: Create IoT Dashboard on V-VAC Platform
You can display and analyze this data using the VOLKKOMMEN V-VAC Platform: V-VAC
Steps to Connect V-VAC :
  1. Log in to your V-VAC account. (Create a new account if not signed up already.)
  2. In the Devices section add a new device.
  3. Select common device and enter the details of the device.
  4. Copy the Device Token and paste it in the MQTT section of the Humido Wi-Fi Web Interface.
For further details check out (How to connect to V-VAC).
Step 3: Wi-Fi Configuration for IoT Device
Enter Configuration Mode.
  1. Press the Config button on the Humido Wi-Fi device.
  2. The Status LED will turn purple, indicating that the device is now in configuration mode.
Connect to the Humido Wi-Fi Network.
  1. On your laptop or smartphone, open the list of available Wi-Fi networks.
  2. Select:
SSID: Humido Wi-Fi (Your_Device_Name)
  1. When prompted for a password, enter:
Password: 12345678
  1. Once connected, keep this network active — it will allow access to the configuration interface.
Open the Configuration Page.
  1. Open a web browser (Google Chrome or Edge recommended).
  2. In the address bar, type:
192.168.4.1
  1. Press Enter — the Main Menu Page will open.
  2. Click on “Configure Wi-Fi” to proceed to the network settings screen.
Add Your Wi-Fi Details
  1. In the Wi-Fi Settings page, enter your router details:
  2. SSID :Your_WiFi_Name
  3. Password :Your_WiFi_Password
  4. Click Save Settings.
  5. The device will automatically restart and connect to your Wi-Fi network.
💡 Tip: Once it reconnects, the Status LED will change from blue (not connected) to green (connected).
Find the Device IP Address
  1. Open your Wi-Fi router’s connected device list or use a network scanner app (like Fing or Advanced IP Scanner).
  2. Locate Humido Wi-Fi in the device list — note down its IP address.
  3. Use this IP to access the Humido Wi-Fi web interface for further configuration.
Step 4: MQTT Setup for IoT Temperature and Humidity Data
Access the Humido Wi-Fi Web Interface.
  1. Open a web browser and enter the IP address you found in Step 3.
  2. The login page will appear.
  3. Enter the default credentials:
Username: User@volk.com
Password: Pass@123
  1. Click Login to access the main dashboard.
Open the Setup Menu.
  1. Once logged in, you’ll see the Main Menu.
  2. Click on the “Setup” option.
  3. This will open the Cloud Settings Page.
Configure MQTT Parameters.
Fill in the following details according to your cloud or broker settings:
Parameter : Value
Server : data.volkkommen.com
Port : 1883
Username :from V-VAC platform (Devices → Setup)
Password :from V-VAC platform (Devices → Setup)
Topic :from V-VAC platform (Devices → Setup)
example → Topic : f898f4a51628f4eb replace it with Device tokenfrom V-VAC platform (Devices).
data-1 : Required interval to send data
Min. relative change in (%) : specifies the minimum percentage change in value required to trigger instant polling.
Min. absolute change in value : defines the minimum change in value needed to initiate instant polling.
Device Name : can be modified for easier identification.
Note : The device name should be less than 15 characters and avoid using spaces between characters
Save and Apply Settings
  1. Review all fields carefully.
  2. Click “Save” to apply the settings.
  3. Once successful, you’ll see green LED indicating an active Wi-Fi and MQTT connection.
Step 5: Real-Time IoT Temperature Visualization on V-VAC
  1. In Dashboard section you can configure widgets for your required data.
  2. Click “Create Dashboard”.
  3. Give your dashboard a name (e.g., Smart Sensor Dashboard).
  4. Click the 3rd icon in the dashboard to open the dashboard.
  5. Inside the dashboard editor, click “Edit” and click "Add Widget" to add new widgets.
  6. In the selection menu choose any widget based on your data visualization needs.
For example:
Card: For displaying single-value metrics
Line Chart: For continuous data
Bar Graph: For comparing sensor readings
Geo Map: For displaying the location of the device.
Thermometer: For displaying the range of the data.
Radial Bar: For displaying the data.
  1. Link each widget to a device telemetry key (the data your device sends).
  2. After customizing your widget, click the Show on Dashboard button to display it on the dashboard.
  3. To save your changes, click the Save button at the top-right corner of the dashboard.
  4. You’ll now see live charts and readings updating automatically.
For more IoT projects and tutorials, visit the official V-VAC Platform - V-VAC.
