Introduction: Voice Controlled Car Using Arduino and L298N
In this Instructable I will tell you how to make a Voice Controlled RoboCar. (COOL 😎)
U will need the following materials:-
Arduino Uno
L298N Motor Driver
Bluetooth Module HC-05
Motors
Chasis
Jumperwires
Bread Board (As per your requirements)
Arduino Uno
L298N Motor Driver
Motors
Chasis
Jumperwires
Step 1: The Code
I like to code first, So here is the code :-
#include
SoftwareSerial BT(0, 1); //TX, RX respetively
String readvoice;
void setup() {
BT.begin(9600);
Serial.begin(9600);
pinMode(4, OUTPUT);
pinMode(3, OUTPUT);
pinMode(5, OUTPUT);
pinMode(6, OUTPUT);
void loop() {
while (BT.available()){ //Check if there is an available byte to read
delay(10); //Delay added to make thing stable
char c = BT.read(); //Conduct a serial read
readvoice += c; //build the string- "forward", "reverse", "left" and "right"
if (readvoice.length() > 0) {
Serial.println(readvoice);
if(readvoice == "*forward#")
digitalWrite(3, HIGH);
digitalWrite (4, HIGH);
digitalWrite(5,LOW);
digitalWrite(6,LOW);
delay(100);
else if(readvoice == "*back#")
digitalWrite(3, LOW);
digitalWrite(4, LOW);
digitalWrite(5, HIGH);
digitalWrite(6,HIGH);
delay(100);
else if (readvoice == "*left#")
digitalWrite (3,HIGH);
digitalWrite (4,LOW);
digitalWrite (5,LOW);
digitalWrite (6,LOW);
delay (800);
delay(100);
else if ( readvoice == "*right#")
digitalWrite (3, LOW);
digitalWrite (5, LOW);
digitalWrite (6, LOW);
delay (800);
delay(100);
else if (readvoice == "*stop#")
digitalWrite (4, LOW);
delay (100);
else if (readvoice == "*keep watch in all direction#")
digitalWrite (3, HIGH);
delay (100);
else if (readvoice == "*show me Garba#")
delay (400);
delay(600);
digitalWrite (5, HIGH);
delay (500);
digitalWrite (6, HIGH);
delay (500);
delay (400);
delay(600);
delay (500);
delay (500);digitalWrite (3, LOW);
delay (400);
delay(600);
delay (500);
delay (400);
delay(600);
delay (500);
delay (400);
delay(600);
delay (500);
delay (400);
delay(600);
delay (500);
delay (400);
delay(600);
delay (500);
delay (400);
delay(600);
delay (500);
delay (500);
readvoice="";}} //Reset the variable
Copy the code from above and upload it, make sure you have the SoftwareSerial. h library.
#include
String readvoice;
void setup() {
BT.begin(9600);
Serial.begin(9600);
pinMode(4, OUTPUT);
pinMode(3, OUTPUT);
pinMode(5, OUTPUT);
pinMode(6, OUTPUT);
void loop() {
delay(100);
delay(100);
delay (800);
delay(100);
delay (800);
delay(100);
delay (100);
delay (100);
delay (400);
delay(600);
delay (500);
delay (500);
delay (400);
delay(600);
delay (500);
delay (400);
delay(600);
delay (500);
delay (400);
delay(600);
delay (500);
delay (400);
delay(600);
delay (500);
delay (400);
delay(600);
delay (500);
delay (400);
delay(600);
delay (500);
delay (400);
delay(600);
delay (500);
delay (500);
Step 2: Schematic
Now, Use the following schematic, and make the circuit.
Step 3: And U R Done
Hope it works, Comment, Like and Share.
