Introduction: Voice Controlled RGB Led
Hello Guys1
Today I am going to show you how to build a voice controlled RGB led using an arduino/Ebot8.
So without any further a due, go to step1.
And good luck in building it!
Step 1: Step:1 Gathering the Required Items
You will be needing the following items to build this project:
Arduino Uno x1
Ebot8(if not using arduino) x1
Bluetooth module (HC05/06) x1
RGB led x(as many as you want!)
Android Phone x1
Play Store x1
If you have gathered it all move on to step 2.
If not....THEN go back buddy.
Step 2: Step 2: Assemble the Circuit.
Connect everything according to what is there above.
Also connect the bluetooth module like this:
tx(bluetooth)-rx(arduino)
rx(bluetooth)-tx(arduino)
vcc(bluetooth)-5v(arduino)
gnd(bluetooth)-gnd(arduino)
If you are using more than led you will h ave to modify that by connecting it first to a breadboard.
But i recommend building it with one then add more.
Once you are done with all that, proceed to step 3.
Step 3: Step 3: Download and Upload the Code
Download the given file and then open it with the arduino code editor,
Verify, compile and upload.
Check if the pins are correct and i have also added some more led's in the code to give you an idea.
get code here:
https://goo.gl/N3pOE8
Step 4: Step 4:Download App and Connect to Module
Donwload this app: https://play.google.com/store/apps/details?id=appinventor.ai_cempehlivan92.Arduino_Sesli_Kontrol&hl=en
and connect to bluetooth module.
Step 5: Step 5: Try It!
Give the command one connected and see it for yourself!
