Introduction: Voice Input Arduino Bi-color LED Matrix Scrolling Text Display (Bluetooth + Android)
While browsing interesting projects at Instructables, we stumbled upon the impressive Voice Activated Arduino (Bluetooth + Android) instructable. You may check it out at https://www.instructables.com/id/Voice-Activated-Arduino-Bluetooth-Android/
Recently, we have put up an instructable to build a 7 Bi-color 8x8 LED Matrix Scrolling Text Display controlled by an Arduino with keypad input from an Android Smartphone via Bluetooth. You may visit https://www.instructables.com/id/Arduino-SPI-7-Bi-color-LED-Matrix-Scrolling-Text-D/ for more detail.
We thought it may be interesting to combine these two instructables to come up with a Voice Input Arduino Bi-color LED Matrix Scrolling Text Display (Bluetooth + Android). We are not sure if you are able to find any practical use for this project but it is FUN to see it work with just some tweaks to the Arduino sketch for the LED Matrix Scrolling Text Display.
You may view the following YouTube video to see what we are building.
Step 1: Building the Arduino LED Matrix Scrolling Text Display
Visit www.instructables.com/id/Arduino-SPI-7-Bi-color-LED-Matrix-Scrolling-Text-D/ for detail on building the Arduino Bi-color LED Matrix Scrolling Text Display. As the display is made up of individual Bi-color LED matrix modules daisy-chained together to form a long display, you may build the display using any number of these LED matrix modules up to a maximum of eight with the Arduino sketch written for the instructable.
To build a longer display with more than eight LED matrix modules, you will need to make some modifications to the Arduino sketch for that project.
Step 2: Programming the Arduino Board
The ‘Android Meets Robots : Voice’ is a free android app brought to us by SimpleLabsIN which uses Android Smartphone internal voice recognition to pass voice commands to your robot, which in our case is the LED Matrix Scrolling Text display.
The app pairs the Android Smartphone with the Arduino LED matrix Display’s Bluetooth Serial Modules and sends in the recognized voice as a string. For example if you say ‘hello’ the Android Smartphone will return a string *hello# to your Bluetooth module where *and # indicate the start and stop characters. However, our Arduino sketch shall filter out the *and # start and stop characters and only display the string.
The Arduino sketch used for this project is based on the sketch used for the Arduino (SPI) 7 Bi-color LED Matrix Scrolling Text Display instructable. The Arduino board needs to be loaded with the Arduino sketch to run the display.
We used Arduino IDE V1.03 for our project. Download the Arduino sketch below for this project which will work with up to 8 Bi-color LED matrices cascaded together. You may amend and enhance the sketch to suit your project.
Download jolliFactory_VoiceInput_8X_Bicolor_ScrollText_SPI.ino
** Note that before downloading sketch to the Arduino, the connections to the TX and RX pins for the Bluetooth Wireless Serial Port Module may need to be removed for the download to be successful.
Note: Having some problems with your Bi-color LED Matrix Display modules? Download the following test program to test each of your modules separately. The display should light up RED, GREEN and ORANGE in sequence row by row to fill up the entire display repeatedly.
Step 3: Testing the Display
Install the free ‘Android Meets Robots : Voice’ apps from the link below.
play.google.com/store/apps/details?id=robotspace.simplelabs.amr_voice
The images here are some screenshots of the Android Meets Robots : Voice app.
To test, power up the display and establish Bluetooth communications between the display and your Android Smartphone. This is done by selecting “Connect Robot” from the Options menu and clicking on your display’s Bluetooth module from the Paired Devices list. Then wait until the app prompts that the connection is successful.
Test the display by clicking on the round microphone button and then speak into your Android Smartphone stating the messages or commands to send to the display.
Below are the commands the display will respond to. Note the words in parenthesis are optional but the voice recognition seems to improve with longer phrases.
Set green (color)
Set red (color)
Set orange (color)
Set faster (speed)
Set fastest (speed)
Set slower (speed)
Set slowest (speed)
Set brighter (display)
Set brightest (display)
Set darker (display)
Set darkest (display)
Step 4: Conclusion
It is interesting to use speech/voice input for the LED matrix Scrolling Text Display. However, Android speech/voice recognition is still not yet perfect and may at times be frustrating as some words, by their nature, are easily confused.
23 Comments
2 years ago
Excellent gammer.
7 years ago
HEY PLS SEND ME THE CODE AND CIRCUIT DIAGRAM OF THIS PROJECT PLSSSSSSSSSSS
email id : ravianpara26@gmail.com
mbil no.:+919549874312
plsssssssssss sir send me please.......
thank you
Reply 7 years ago
The code can be downloaded in
7 years ago
hi... i just want to say thank you very much for your help...its really help me a lot.
i'm glad that i can finish my project in time...
Best regard,
Thank you.
7 years ago
Hello, i am using your coding for a references to my project but the words are not coming out when i speak i don't know what is the problem. I guess i have a problem with the bluetooth connection seem like it is not detected. may i know the connection for the bluetooth? any suggestion for me?
Reply 7 years ago
Hope it is helpful to you. Check out link below.
https://www.instructables.com/files/orig/FO5/WCRG/HURHP4IR/FO5WCRGHURHP4IR.png
Reply 7 years ago
Thank you.....i'm so sad it is not working...do u have any other way? in the coding which part shows the bluetooth connection? is there any? i know it is RX and TX but its just the scrolling effect that I've got rite now...
Reply 7 years ago
You may check out my other instructable available at
to test your bluetooth connections and communications are working before you work on this instructable.
7 years ago
please send me the circuit diagram for connecting arduino to LED matrix driver max7219
Reply 7 years ago
Check link below:
Reply 7 years ago
Check link below:
7 years ago
Can you scroll the text reversed? (Readable in a mirror)
Reply 7 years ago
Yes, but you will need to modify the code. We managed to modify the code for mirrored scrolling text.
You may get hold of the LED Matrix modules from
https://www.tindie.com/products/Nick64/60mm-x-60mm-bi-color-led-matrix-driver-module-diy-kit/ and try to modify the code yourself. If you tried very hard and is still unable to get mirrored scrolling text, let us know and we will guide you to make it work.
8 years ago on Introduction
can you combine the voice feature with the presets you had in the original scrolling led post? i'd love an app that had preset features along with the voice feature.
Hello dear friends would like to get the code to do.
I made it, Thanks.
Glad you made it.
Will greatly appreciate if you could help me write a review for the LED Matrix kit you purchased from my Tindie store https://www.tindie.com/products/Nick64/60mm-x-60mm...
9 years ago on Introduction
plz help me on my thesis, the title of my thesis is LED lights voice recignition in android apps with self timer
Sorry. I am not sure how I am able to help with your thesis.
