Introduction: Voronoi Dog
Hi All,
In this instructable, I will share, how I made this Voronoi pattern dog
- 3d Printer
- Meshmixer
- Cura
- TinkerCad
Step 1: Download a 3d Model
- Go to your favorite 3d Model site
- I like Thingiverse.com
- I would recommend picking a low poly model instead of full poly
- For this instructable I used https://www.thingiverse.com/thing:446787
- You can choose any other model too
my model is avaliable at https://www.thingiverse.com/thing:4792489
Step 2: Meshmixer 1/3
- If you do not have Meshmixer, download and install from https://www.meshmixer.com/download.html
- Import the stl file into Meshmixer
- After import, you will notice the surface is different than you expected
- To fix this, click on Edit and select Generate Face Groups, This should fix the shape
- Now under Edit, select Make Pattern
- As soon as you select it, the default is Tiled Tubes, you can change the pattern using Pattern Type dropdown
- You can experiment with the different patterns but for out Voronoi we need to select "Dual Edges" or "Mesh + Delaunay Dual edges"
- You can play with the "Element dimension" and "element spacing" for desired thickness
- Once happy, press the Accept button, it may take a few minutes while Meshmixer processes the model
Step 3: Meshmixer 2/3
- After Meshmixer is done processing, it may have cracks or error
- In this case, it does show them as red dots
- Just to be sure, select Analysis and then Inspector
- You will be able to see all the defects, I typically select Auto repair all and then Done
Step 4: Meshmizer 3/3
- Many times the base of the model is not flat, it may not print well
- To avoid this you can either slice the base by 0.5 to 1mm
- Or Add a base
- I created a 2mm thick 100mm circular disc in tinkercad, and export it as stl file
- Now import this disc in Meshmixer, select Append
- Use object browser to select the disc and Generate face groups
- Under Edit, use transform to align the dog and the base
- In Object browser select the dog and the base, option to combine automatically pops up
- Select Combine and then export the model
Step 5: Cura Settings
- Install Cylinder custom support and restart Cura
- Import the model in Cura
- Do not activate Supports use custom supports
- We need to add support where needed, for this model, I added just on
- Resolution 0.28mm
- Reduced scale to 80%
Step 6: Printing and Cleanup
- Export the gcode from Cura and print it
- It took 3.5 hrs for me
- Once done, you will notice that there is a lot of stringing
- Use a hair drier to melt the string
- Since we did not use supports, there will be some sagging but does not standout
I hope you will try this method and do share your feedback and suggestions
