Introduction: WALL-E Clock & Lamp
That cute wall-e will give you time, a bit of light and a lot of love.
As you'll see, I integrated a resistive touch screen. It's not our smartphones' touch screen, which are capacitive screens. This one consumes very little energy (convenient to save battery). The downside is that it's a little less responsive, less fluid, but for this, it is more than enough.
Features:
- Clock
- Alarm clock
- Lamp
That's simple and very cute.
Normally it's pretty easy to make it but you'll need to be patient.
I sell all components in my website: https://jeje-linge.fr/en/products/alarm-clock-and-wall-lamp
The battery: https://a.co/d/3ZW8Pab
Right_leg.stl
right_wheel_bracket.stl
Screen_block.stl
small_wheel_axle_x4.stl
small_wheel_x8.stl
tread_x4.stl
arm_inside_long_.stl
arm_inside_short.stl
arm_outside_long.stl
arm_outside_short.stl
Big_middle_wheels_axe_x4.stl
big_wheel_x4.stl
body_back.stl
body_bottom.stl
body_left.stl
body_right.stl
body_top.stl
front_door.stl
hand-axle-x2.stl
hand-bracket-x2.stl
hand-finger-left-x2.stl
hand-finger-middle-x2.stl
hand-finger-right-x2.stl
head_back.stl
head_eyes.stl
head_pin_x2.stl
Left_leg.stl
left_wheel_bracket.stl
medium_wheel_x4.stl
neck_non_electronic.stl
Power_supply_board_block.stl
Step 1: Assemble Wheels
Assemble the right and left wheels with the tracks.
Step 2: Assemble Arms
Assemble the right and left arms.
I preferred a long arm to carry the bulb, and a shorter arm for the rest.
But you can make two long arms two short ones... As you want.
Step 3: Painting Part 1
I'll start by putting a bit of grey wash on all the pieces.
Step 4: Painting Part 2
Then use grey and brown paint, to give a slightly rusty appearance.
Step 5: Lens in the Eyes
For the eyes, I'll add something that is not obligatory, but I think it gives a bit of style, it's small lenses (29mm).
Step 6: Glue the Wheels
Assemble the wheels to the lower piece.
Pay close attention, the big wheel, which go to the back.
Step 7: 2.8 Touch Screen
I use wires with female connectors, because it's simpler than soldering.
We're not using the T_IRQ.
The T_DO, T_DIN and T_CLK will be solder direclty to the SDO, SDI and SCK
Step 8: Power Board
It will power the entire system.
Wire a 18650 battery to it.
Step 9: RTC Module
The RTC module will allow you to have a reliable clock.
Don't put a battery at the back, it's useless.
Step 10: MP3 Module
Don't forget to put the MP3 files on the microSD card.
Step 11: Relay and Bulb
On the D+, put a red wire which will then go to the VCC.
On the D-, put a black wire which will go to the GND.
On the IN input, which controls the relay, to know if it is open or closed.
Step 12: The Bulb
Solder a black and red wires on the bulb.
If the tin doesn't stick well enough, you can sand the connectors a little bit.
Step 13: Voltage Divider Bridge
Solder 2 resistors together and add a wire in the middle for the tension to be divided.
This will give you an idea of the state of charge of the battery.
Step 14: Connect Modules
Connect every module to the ESP32.
Do not wire the battery to the GND Wago to avoid powering the whole thing.
What do first is connect the ESP to the PC and send the program.
Step 15: MP3 Files
Put your micro SD card into your PC and send the MP3 files on the micro-SD card.
Keep the MP3 folder don't put the files in the root.
Step 16: Send the Code
Install the TFT_eSPI library.
Once the library is installed, you go to your documents, then in Arduino, Libraries and you should see it appear here.
In this folder, you have a file called User_setup.h
Open it in a text editor.
We're simply going to uncomment the lines (see picture)
Touch_CS we'll replace 21 by 5.
Go back to the Arduino IDE and click on upload.
Download the code here : https://github.com/jejelinge/WALL-E
Step 17: Touch Screen Calibration
First thing to do, insert the micro SD card in DFplayer with the MP3s on it.
Your screen should be in calibration mode, and asking you to touch the four corners.
You can now connect the battery.
Step 18: Put Screen and Speaker
First put the screen in the front part.
On the back, put the speaker.
Step 19: Power Board
Once the speaker's on, put the small power board in the hole of the back part.
Step 20: Assemble Sides
Take the sides and glue them.
Step 21: Assemble Arm and Bulb
Take the light bulb arm, and the light bulb.
Pass wires one after the other through the arm.
Then, pass the wires through the hole, and force the arm in.
Step 22: Assemble Second Arm
Put the second arm in the same way.
Step 23: The Head
And finally, we put the head.
