Introduction: WEATHER BOX USING ARDUINO ~THE EASIEST
How Does it Work?
Check the temperature around you with this Smart device!
For more Intresting Projects Visit : www.miymakers.com
Facebook : www.facebook.com/miymakers
Step 1: HOW IT WORKS?
How Does it Work?
The DHT11 is a basic, ultra low-cost digital temperature and humidity sensor. It uses a capacitive humidity sensor and a thermistor to measure the surrounding air, and spits out a digital signal on the data pin (no analog input pins needed). Its fairly simple to use, but requires careful timing to grab data. The only real downside of this sensor is you can only get new data from it once every 2 seconds, so when using our library, sensor readings can be up to 2 seconds old.
Step 2: THINGS REQUIRED
Things Required
>Arduino Uno
>DHT11 ~ Temperature and Humidity Sensor
>16*2LCD SCREEN
>POTENTIOMETER
>JUMPER WIRES(male to female & Female To Female)
Step 3: USING HEADER PIN
USING HEADER PIN
Use header pin so that You can easely make this project using only MALE TO FEMALE & FEMALE TO FEMALE JUMPER WIRES
Step 1: Place the Header Pin into the pins of Arduino After it glueing it will look like this.
Step 2:Using GlueGun, Glue the header pin to Arduino so that it does'nt become loose.
Double check whether the header pins are not loose,otherwise there will be no output from the pin!!!
Step 4:
Step 5: BOX
Take a an appropriate Plastic Rectangular box,
Make holes for the LCD and DHT11 Sensor
Step 6: CIRCUIT
CONNECT ARDUINO ACCORDINGLY!
DOUBLE CHECK!
LCD Connection
D7- DIGITAL PIN 2
D6 - 3
D5 - 4
D4 - 5
E - 11
RS - 12
VDD (+) RAIL BREADBOARD
A (+)RAIL BREADBOARD
VSS (-)RAIL BREADBOARD
K (-)RAIL BREADBOARD
RW (-)RAIL BREADBOARD
Step 7: DHT11 Datasheet
Datasheet for Dht11
Please download the DHT library from the above link.
Then Open Arduino IDE Go to Sketch --> Include Library --> Add Zip File Close the Arduino IDE and open it again then you will find the library included.
For more info : https://www.arduino.cc/en/Guide/Libraries
Step 8: Code
Code
Download the Code from the link and open it with Arduino IDE.
<p>//WEATHER BOX tutorial!<br>//Get more tutorials on --> --> --><br>//"MIYMAKERS" https://miymakers.wordpress.com/</p><p>#include <dht.h></dht.h></p><p>#include <br><liquidcrystal.h></liquidcrystal.h></p><p>#define dht_dpin A1 //no ; here. Set equal to channel sensor is on<br>dht DHT;</p><p>LiquidCrystal lcd(12, 11, 5, 4, 3, 2);<br>void setup(){<br> <br> ;lcd.begin(16, 2);<br> lcd.print("TEMP HUMIDITY");<br> Serial.begin(57600); <br>}<br>void loop(){<br> lcd.setCursor(1,3);<br> DHT.read11(dht_dpin);<br> </p><p> //lcd.print(abs(moisture)); <br> //Serial.println(moisture);<br> lcd.print(round(DHT.temperature));<br> lcd.print("C "); <br> lcd.print(round(DHT.humidity));<br> lcd.print("% "); <br>}</p>Step 9: Done!
You can see the Current Weather on the LCD screen....
You can adjust the contrast (Sometimes the display might be blured)by turning shaft of the Potentiometer!
