Introduction: WIRELESS SPEAKER USING LASER
It will be always fun to play with music and with lights,here it is
the project “Wireless audio transmitter” has both music and light which is to connect the audio source device such as laptop,mobile phone ,dvd player ,etc.., and speaker through laser light .This works perfect for straight line communication of distance 50 meter and more (depends on laser quality ).
This device has two sections i.e, transmitter circuit as sender at audio source side and receiver at speaker side
Step 1: THIS IS HOW IT WORKS
The working principle of this device is very simple by varying the intensity of laser beam according to the amplitude of audio signal and directed towards receiver section solar panel,as it involves in audio amplification modulation transmission demodulation amplification and output (to speaker)
Step 2: REQUIREMENTS
Required components and tools
Lm386 ( audio amplifier) -2Nos
Resistors
10ohm -2Nos
100ohm -1Nos
56ohm -2nos
220ohm -1nos
Potentiometer
10Kohm -2Nos
Capacitor
10u/25v -5Nos
100u/25v -1Nos
0.047u/25v -2Nos
Small size project board -2Nos
Speaker (8ohm) -1Nos
Battery (9volt) -2Nos
Laser light -1 pcs
3.5mm audio jack (male) -1pcs
Solar panel (may from old calculator) (10mmx25mm)
Connecting wires,Soldering iron,alligator clip
Step 3: TRANSMITTER
The transmitter section contains an lm386 based audio amplifier circuit which will amplify the audio signal from the mobile phone (source),which is the connected the laser light. As audio signal is nothing but variation in the amplitude and frequency of continuous signal, so depends on the amplitude variation in the audio the intensity of laser light will get varied which should be directed towards receiver side circuit
The audio to this transmitter is given through 3.5mm audio jack from mobile or any other audio out from other devices.this incoming signal will be amplified by lm386 audio amplifier and used to vary the intensity of laser beam.
Step 4: RECEIVER
In receiver side it has an solar panel on which the modulated laser beam should made to flow.The solar panel will now convert the laser beam back to variation voltage level similar to audio signal. Now it is amplified by lm386 audio amplifier and send to speaker
Thus the simple wireless laser speaker was made.
