Introduction: WIZwikiREST-io
WIZwikiREST-io is so REpresentational, State, Transfer.
Most of all may know RESTful. And Now the great flow is REST.
No one wants complex and heavy.
No Protocol and Just Architecture are the heart of REST.
I do not mention about RESTful here but If you never hear about it, need to know.
This WIZwikiREST-io ' point is Really Simple!!
What I do is to make simple platform for all.
'All' is really All.
Could you imagine kids never learn about C/C++ turn on/off leds?
Could you imagine kids never learn about C/C++ make IoT device?
Isn't impossible with WIZwikiREST-io.
It is no need Code. Only need simple hardware (unless connect leds to ECO board..)
Every WIZwiki-W7500ECO pins become resources and these resources are mapping Only URL.
It means using URL(HTTP) possible to control WIZwiki-W7500ECO. No Need Code.
Now I will tell you more details, Please follow me!
Step 1: GET Method
This is WIZwiki-W7500ECO board Pins map.
As this capture, Every Pin has Only URL.
It means with the URL, users can control or check the Pin state.
Type URL in web browser and press Enter Key, Web send GET packet to WIZwikiREST-io.
WIZwikiREST-io returns the Objects and values.
Step 2: POST Method
This capture show the difference between WIZwikiREST-io and others.
WIZwikiREST-io does not String Compare. It make all things JSON Objects.
When received POST Packet, WIZwikiREST-io make the data JSON Objects and compare with it's Member Object.
Then do Callback functions and Response to Client.
For TEST, I used POSTMAN (google Plug-in).
It is So great program for http method Test.
It support all methods.
After send POST packet in POSTMAN, captured it with Wireshark.
Step 3: Features
Step 4: Published
Now this platform is opensource and It is in mbed.org
Anyone can download this platform.
But if you want to use other bourd ( I use WIZwiki-W7500ECO), you need to work for porting.
Next time, I will Add the App that I control led matrix with.
