Introduction: Waffle Balls
Waffle balls (or pancake balls) was something I decided to try by using a cake pop maker and pancake mix.
Waffle balls are great for little kids especially because they instead of having a parent cut up a child's waffle/pancake, it is already in bite size pieces for them! They are also easy to dip! They also do not cost to much because you basically just need waffle/pancake mix, water, and a cake pop maker.
Step 1: What You Will Need
What you need:
-cake pop maker
-waffle mix
-water
-nonstick spray
-chocolate chips (optional)
Step 2: Getting Started
First, get out your cake pop maker. Make sure your the cake pop maker is clean before you use it. Then, spray it with the nonstick spray so that the waffle balls come out easier. DO NOT PLUG THE CAKE POP MAKER IN YET!
Step 3: Time for the Mix
Now you will start to make the pancake mix. Follow the instruction on the pancake mix container. In my case all you have to do is add water. Then, if wanted, add chocolate chips to the mix.
Step 4: Pour It In
Now you are going to pour the mix into the holes of the cake pop maker. Remember to fill the holes all the way to the top with the pancake mix. Once all of the mix is in and ready, you can plug in the cake pop maker.
Step 5: Almost Done
Now all you have to do wait for the cake pops to finish and ten scoop them out. You want them to be in there for about 2 min.
Step 6: Ta-da
Now once you have waited, it's time to scoop out your finished project! I recommend using a small spoon to scoop them out . Make sure when you scoop them out that all the edges aren't sticking to the cake pop maker to make sure they don't rip. And ta-da u r done!
