Introduction: Wall Hanging
Hi Friends,
I am sharing this simple Instructable to make beautiful wall hangings. You can use mine for reference.
Materials required:
Desired Design
Basic Stationary
Stencil cutter or precision knife
Self adhesive coloured Glitter Sheets
Waste Cardboard
Black cloth for background
White or Blue Carbon sheets
Step 1: Step 1: Wall Hanging
Once All your supplies are ready, you can start.
First cover the cardboard with cloth and make your base ready.
Here, I have used black colour cloth. You can use according to your liking and the selected design.
Always keep the contrasts in mind.
Step 2: Step 2: Wall Hanging
Once your base is ready,
Have the Design Trace ready
You need to copy your design on the base.
This is done using carbon sheets.
White carbon sheet is used to draw on dark fabrics and vice versa.
Step 3: Step 3: Wall Hanging
once the design is traced on to the base, it needs to be traced on to the glitter sheet too.
Select the desired coloured adhesive glitter sheet.
Reverse it and trace the design using the carbon sheet.
VERY IMPORTANT ..be mindful of left and right of the design as this migh cause problem while sticking it to the base.
The third image is the one with the drawing behind the glitter sheet.
Compare the drawing to the final result, when i peel the sticker, i should be able to stick it correctly on the base.
Step 4: Step 4: Wall Hanging
Once you have traced the design onto the back of the glitter sheet, Its time to cut the pieces carefully with the precision knife one by one.
keep your base ready beside you, peel the peep off and stick it securely at the right place on the base design.
Step 5: Step 5: Wall Hanging
Carefully cut the pieces and keep filling the gaps one by one and LO!...your wall hanging is ready.
Use accessories to enhance the design.
Here I have used the design of Lord Ganesha.
Thank you friends.
