Introduction: Wanna Build a Bad A$$ Rc Plane Cheap?
It's easy cheap and satisFRYING
Step 1: Supply or Die
go to lowes or home depot on Saturday or Sunday this is the best time to catch beautiful ladies shopping while you get your supplies. If you happen to hook up blow off the rc plane for now. I'll understand. ..;)
Step 2: You May Wanna Write a List
if your phone dies at the store you will think me
Step 3: Comb You Hair Over We Are Going Shopping
Once you are there and struck out in the lady dept go grab yourself a 4x8 sheet of blue foam. it comes in 2 thickness as a rule either will work. look for pieces that are broken on the corner or crushed o little on the side. hit up the Dept. Mgr and ask for the foam at half price. You may want to get the foam last or you will look like a idiot walking they the store with a big piece of foam. Also grab some titebond quick set glue. don't be a tie wad. get a big bottle cheapskate it's just glue. Now I'm guessing you have a palm sander at the house if not stick to buying over priced ARF planes. get some 80,120,220 and some 300 to 600 pads. Now grab a roll or two of clear packing tape. get the good stuff. let's see....what else... razor blades are always good too. and while your there could you grab me a filter for my shop vac? it's the least you could do for all this info and typing I'm doing.
Step 4: PUT SOME MEAT IN THE BEAN
Go home and close out the porn sites on your lap top. it's time to get some info. there are a lot of things you can build. But by far imo the wing is the sexiest, cheapest, coolest, easiest to fly plane to start on. Do this in Google Chrome browser it what works. Quit questioning me ! search for rc wing calculator ver 2. v1 is ok and so is v3 but trust me on this. Depending on weather or not you are in Canada or the US use millimeters or inches. you can play with this to get the look you want. Now is a good time to look at the expensive store bought trash that came as a ARF almost ready to fly. You want to consider the wieght of the donor plane so you can build your wing about the same. or go to hobby king and buy what you need. but if you are reading this. you are a victim of a overpriced plane you wrecked 1st time out. mine won't break so easy.
Step 5: Ok Ok I'll Tell You Some Good Ones
2 Anna go big ??? 64 inch wing span 12 inch root 6 inch tip sweep is 14 inch. this is good for a 4 cell setup and a strong motor that will pull 3 lbs. anything with a 12 root and 6 tip and 14 sweep is good for pusher add a fuselage if you choose for fpv. for a tractor (prop in front) 36 ws 22 root 8 tip and 3 inch fuse is good. confused? read and learn it's all out there if you don't know this much this is to advanced for you. You need to study a bit to enjoy planes like this.....
Step 6: If Your Keeping Track It's the 6th Step and Your Anal Retentive.
now you think you know your design right? well cut out the entire wing from the foam. now cut two sections to match leaving a gap where you want your batteries to go. as illustrated cut 1st piece and then 2 and 3. brush a thick layer of tie bond on the 1st piece but not in the middle where the gap goes. that would be stupid. now wouldn't it? ...Place the 2 parts on top of the 1st and shit your heavy girlfriend on top and tell her not to move. and you will buy her a bow of twinkies. let sit for 2 days to dry fully. no air gets in there if you can see in the sun it will speed it up. note.
Take time to cut this with new sharp razors it matters.
Step 7: Dry Time
not sure what it is you do to pass time but I hope the farm animals are safe
Step 8: Let's Do This
start building up pieces to shape your ideas in foam glue foam stacks ans sand away with 80 grit to get close to the she you want. sand light and slow you can always sand off more
Step 9: Once Your Close
add slots for servos and wire a thin piece of plywood to mount your electronics and do the same for a cowling. none of this is hot wires this is all free hand sanding
Step 10: Fins and Stuff
build some vertical stabilizer fins and wait to install. just fit for now
Step 11: Get Your Tape On
cover it feom back to front with the packing tape. OVERLAP the tape about 1/4 inch FROM BACK TO FRONT I SAD
Step 12: Sex It Up
Vinyl from your local sign shop or fiberglass it with 3/4oz glass you can use polycrylic waterbase and do it inside no fumes. or cover it with Monokote or fabutex
Step 13: Power to the People
if you have the skill go big
Step 14: Gentlemen Start Your Hoopties
drop the motor in and all the electronic parts
Step 15: Maiden
if u suck you will crash and burn but that's ok just build another you have plenty of foam left.
Step 16: 100 Mph Screw Up
from 200 feet up I lost power and it slammed in the ground at about 80 mph it will fly on a few days agian
Step 17: Get Off Your Donkey
I've built em all and flown em all and trust me this is the best way to get into building. dollar tree foam board is ok but at the end of the day it's still foam board. you now can build a real damn plane. and noone else will have anything like it. I will answer any questions I can. as long as there not stupid.
Step 18: Thanks
hope you can enjoy my humor and build techniques if you cant. then I have another instructable on how the screw..........bye
Step 19:
