Washers Game (or Urban Horse Shoes)
Intro: Washers Game (or Urban Horse Shoes)
Do you like the game Horse Shoes, but unfortunately live in the city and don't have the yard space? Maybe you just can't throw those heavy metal U's. Whatever the reason, Washers is a simple game for the whole family or college student that's simple to play, quick to set up and break down anywhere (grass, stone, dirt, pavement). The following instructions are how to build my version of the game: Washers.
STEP 1: Gather Materials and Tools
Materials List:
2 - 12 length of Nylon Rope
2 - PVC pieces; 3 " height and 3 " O.D.
6 - Galvanized Washers; 2 O.D.
4 - Decorative L brackets (solid brass)
4 - Nuts and bolts for L brackets
16 - 8x3 wood screws
8 - 1 " wood screws
2 - 14x14 squares of artificial grass
2 - 14x14 squares of plywood (3 ply thick)
4 - Nail staples (to secure rope)
2 - Cans of spray paint (two colors)
1 - 10" length of 2x4 wood
1 - Can of clear wood finish or stain
1 - Box of staples
4 - Latching or locking mechanism
2 - Magnetic retriever tools
All in all it'll cost almost $30 in materials (assuming you have tools already).
Recommended Tools:
Drill
Philips Screw driver
Circular saw
Staple gun
Hammer
Paint brush
Wood burner (optional)
8 - 1 " wood screws
1 - Box of staples
Recommended Tools:
Drill
Circular saw
Staple gun
Hammer
Paint brush
STEP 2: Assemble the Frame
Assemble the 2x4's into a 14x14 square frame using the 3 wood screws (miter the
joints or butt lengths together; pre-drill holes for the screws)
STEP 3: Da'Grass!
Staple the 14"x14" pieces of artificial grass to the squares of plywood. You could use any type of fabric or carpeting. I picked up some scrap outdoor carpet grass at the local hardwood store for pennies.
STEP 4: Bottom
Attached each 2x4 frame to a square of plywood.
STEP 5: PVC (the Cup)
Drill 2 holes in each piece of PVC for the L brackets (use the brackets to
measure hole placement). Then attach the brackets to the PVC (using nuts and bolts).
Put the PVC inside the box using small screws through the open L bracket holes (make sure to center the PVC in the box).
STEP 6: Handles
Nail the 2 lengths of nylon rope with the staples to make handles on the boxes.
STEP 7: Latching
Attach latching or locking mechanism to the completed boxes. I put one on each side. There are a number of styles to use depending what you find at the store.
STEP 8: All Finished! and Rules
Finally, just spray paint the galvanized washers two different colors (Red vs. Blue).
And play Washers
Rules:
Two teams of two (red vs. blue);
Set boxes approx. 12 ft apart (may offset boxes)
One person from each team throws washers into box alternating turns
Scoring:
Washer in box or on top rim of box = 1 point
Washer leaning on cup on inside of box = 2 points
Washer inside of cup (leaning or flat) = 3 points (a cupper!)
Every washer counts, Colors cancel out.
First team to 21 points wins.
Scoring Example One: 1 blue in cup; 1 red in cup, 2 red in box Score = 2 points for Red Team.
Scoring Example Two: 1 blue in box, 1 blue in cup; 2 red in box, 1 red leaning on outside of cup Score = O points, round draw.
And play Washers
Rules:
Scoring:
25 Comments
Andrewshantz 10 years ago
CaseyB5 9 years ago
You can also install a PVC flange to the bottom with nuts and bolts, and then glue the PVC pipe in the flange with PVC cement. I'd cut a whole in the carpet and place it over the pipe so the thickness of the carpet does not cause the pipe to be higher than the sides of the box. It should be at the same height. Good instructions though!
the_Magnificent_Macak 10 years ago
pclive 11 years ago
"Scoring Example One: 1 blue in cup; 1 red in cup, 2 red in box Score = 2 points for Red Team.
Scoring Example Two: 1 blue in box, 1 blue in cup; 2 red in box, 1 red leaning on outside of cup Score = O points, round draw."
Shouldn't 'Scoring Example One equate to 4 points for Red Team?
1 blue in cup (3 Points) [Cancels out]
1 red in cup (3 Points) [Cancels out]
2 red in box (4 Points)
Score = 4 points for Red Team.
Shouldn't 'Scoring Example Two equate to either 3 points for blue and 4 points for Red....or just 1 point for Red?
1 blue in box (2 Points) [Cancels out]
2 red in box (4 Points) [Cancels out only 2 points leaving 2 points to Red]
1 red leaning on outside of cup (2 Points)
Score = 3 points Blue, 4 points for Red
or
Score = just 1point for Red
the_Magnificent_Macak 11 years ago
You might be confusing a leaner against the outside of the cup (2 points) verses just 1 point for getting it in the box (no leaner).
pclive 11 years ago
"Washer leaning on cup on inside of box = 2 points"
I read this as "Washer leaning on cup [OR] inside of box = 2 points"
Your scoring is correct. Sorry for my confusion.
timweaver17 13 years ago
the_Magnificent_Macak 13 years ago
bhunter736 14 years ago
webman3802 14 years ago
the_Magnificent_Macak 14 years ago
myWoodenCow 15 years ago
binglebeebop 15 years ago
snobahr 15 years ago
adidame 15 years ago
Lost Moai 15 years ago
johnjoejohn1 15 years ago
