Introduction: Water Bottle Bird Feeder and Bath
Materials Needed
- Plastic Bottles(2)
- Scissors
- Marker
- String
- Bird Feed
- Sticks(2)
- Ruler
Step 1: Marking the Bottles
- Mark a small dot on the side of the bottle 2 inches from the bottom
- Mark a second small dot one quarter of the bottle’s circumference away
- The second dot should be at the same height as the first (2 inches from the bottom of the bottle)
- Next draw a circular/oval shape 1 inch above each dot. These circles should be about 1 inch in diameter.
- Repeat the circle outline on the direct opposite side of the circles
- There should be 2 dots and 4 circles marked
- On the second water bottle, mark a line across the circumference at the top of the bottle. Put the line 2.5 inches from the top of the bottle
- On the second water bottle, mark a dot 0.5 inches above the line
- Repeat this dot on the direct opposite side
Step 2: Cutting
- Use the scissors and poke a hole in the bottle where each small dot is marked on the first bottle
- Then use the scissors and cut out each circle outline. It may be helpful to pinch the bottle in order to make the initial cut.
- Cut at the line on the second bottle off by following the line that was drawn.
- Poke holes where the dots are on the second bottle
Step 3: The Perch
- Take a stick and push it through one of the small holes that was created by poking through the marked dots (On the first bottle)
- Push the stick so it is hitting the edge of the bottle from the inside
- From the outside use the marker to make a dot.
- The stick should be straight across, so the dot will be at the same height
- This dot will mark where the perching stick will exit the bottle
- Poke a whole with the scissors at the new dot
- Push the perching stick through the original hole and out of the new hole
- The stick should be protruding out of both sides
- Shift the stick so the perch on each side is equal in length
- Repeat these steps for the other small hole in order to create the second perch
- By the end of this step there should be two sticks crossing over in the bottle
Step 4: Inserting the Bird Feed
- Take the top piece of the second bottle that was cut off in step 2
- Remove the cap if it is in place
- This will act as a funnel, and help to reduce spillage of the birdseed
- Some spillage may still occur, it is recommended to fill the bird feeder over a trash can or outdoors
- Take the birdseed and pour it through the funnel and into the bottle
- You will know the bottle is full when the birdseed begins to come out of the holes
Step 5: Birdbath
- Take the funnel piece from the previous step
- Put the cap back on
- Take a piece of string and pass it through the poked hole from the outside
- Pass the string through the other hole
- Pull both ends of the string so that there is an equal amount of string on each side
- Tie one end onto a perch stick
- Tie the other end on the same perch stick but on the opposite side of the bottle
- Once the string is knotted on each side, pull the knots along the perch until they are touching the bottle
- This will hang below the feeder
- Do not fill with water until feeder is hung
Step 6: Hanging the Bird Feeder
- Remove the bottle’s cap
- Take the scissors and poke a hole in the center of the cap
- Take the string and push one end through the cap a few inches
- Tie a knot at the end of the string, make sure it is on the side of the string that will be inside the bottle
- Pull the string so that the knot is up against the hole (the knot stops the string from passing back through)
- Put the bottle cap back on
- The rest of the string that is coming out of the bottle cap is for hanging the bird feeder
- Tie the rest of the string in order to create a loop
- Then hang the bird feeder wherever you would like
- Once it is hung fill the bath with water
2 years ago
Very nice project for upcycling an old bottle :)
