Introduction: Water Floating Candle
MAKE STUNNING WATER FLOATING CANDLE.
Step 1: ADD WATER IN THE GLASS
First step is to add water in the glass upto desired level.You can even make glowing water by adding highlighter ink inside it.
Step 2: MAKE FLOATING WICK
Make floating wick by passing the wick through OHP sheet or any other plastic material that can float on water.Make sure that the cutting of the sheet is of same size as that of the opening of the container.Pass wick through the centre of the cutting.
Step 3: ADD OIL IN THE CONTAINER
Add oil in the container glass above water. oil wont sink as it floats on water.Form a desired layer of oil obove water.
Step 4: PUT FLOATING WICK IN THE GLASS CONTAINER
The wick will float on the oil.
