Introduction: Water Fountain
this is what the final product should look like
materials needed
some of the materials i got from hobby lobby and amazon
as for plants and rocks from home
also need a container like 2ft tall
Step 1:
first drill a hole at the bottom of the small bowl and put the plastic tube securing it with hot glue and also from inside the bowl securing it with glue around it
Step 2:
second grab a container drilling a whole at the bottom putting the plastic tube in it and secure it with hot glue
Step 3:
when you put the plastic tube in the small bowl should sit on top and secure it with hot glue
Step 4:
on the other end of the container make two cuts on both sides so it sits on top of the big bowl and add hot glue
Step 5:
then to the small bowl you want to make a cut on the side make make sure it big enough so the water can come out then i used an easter egg and cut it so that the water can fall down and into the other medium bowl and adding hot glue
should look something like this
Step 6:
now with the other bowl repeat doing the same cut on the side
Step 7:
finally is the final touches before adding the rocks put the water pump in the bowl and use the rocks to cover it i made sure to add enough rocks so that the second bowl can sit on top and then added water, plants, and roses as decor
Step 8:
now add the bowl from where the water is dripping sitting it on top of the rocks and done!
